![]() | Home > Technical (L322) > Dent removal |
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 ![]() ![]() ![]() |
I've managed to put a scratch-dent in a front door, at about the height of the front bumper |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7943 ![]() ![]() ![]() |
Not sure about the rest of it, but there is a screw behind the little Airbag label thing, which I think you have to remove. Pop the cover off the door card and you'll see it.
Andpopse Member Since: 16 Oct 2010 Location: Bristol Posts: 100 ![]() ![]() ![]() |
PDR (paintless dent removal) deffo the way to go. I had a dent in the roof of my BMW (caused by a conker !). They did a thing called glue pull. and is was sorted, cost about £70 from memory
Thanks guys.My paint is off, but I like the idea of the glue pull avarient of the spot eld rods to pull on Wurth has a glue-pull set I think, but it is bloody expensive. I wonder if a strong epoxy would stand up to a few forceful pulls with a Morgan -knocker type puller? Food for thought and worth trying. I've tried on other vehicles, welded rods, but it's not so easy grinding down the weld flush afterwards.Glue should remove easier, later. Range Rover Vogue TD6 2002
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Type "dent repair" into Amazon
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Ditto the paintless dent recommendation. They are the true alchemists o the modern age. |
