![]() | Home > Maintenance & Mods (L322) > Door mirror cover |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Picture so we can see what type you have? (always tricky @ 2005 |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
Once I have worked out how to cut and paste photos in here from my ipad I will oblige.[/img] |
Like this?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
You are struggling because they don't come off... They are plastic welded together... |
I have seen these photos and they look the same except my light is rectangular |
Not sure what you mean Craig. The rectangular surround comes off quite easily. It appears that the main body, which is all in one piece, unlike others which are split half way up, can not be removed without detaching and dismantling the whole mirror assembly. |
If it is the same as mine (original '02 > ) then the main cover (the big bit) should just fall off IIRC as it is only held on by the ring @ the mirror.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
Mine are like that and I don't think it is an easy job to remove the casing. It seems to be screwed/bonded in place from inside. Land Rover sell the covers that stick on top of them, and they work very well I bought some Java Black ones from Duckworths.
All the good FF's came factory fitted with the body coloured covers |
NOT the same as mine |
As I said, you have a facelift car with later mirrors that are not designed to come apart as they are plastic welded together in the factory... |
