![]() | Home > Maintenance & Mods (L322) > What preventative maintenance should I do? |
| RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 226
Change oil in front and rear diff and transfer box 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
| scorpiont10 Member Since: 30 Aug 2012 Location: Mansfield Posts: 6
Maybe check the rear washer/wiper for leaks/signs of leaks by removing the plastic trim at the top of the tailgate ( you will be removing this to do the camera anyway) . If there are any water marks on the plastic, it would be a good idea to replace the nrv and carry out the seal repair detailed elsewhere on the forum |
Put it in your garage and remove the wheels! |
| Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74
Good plan, forgot about those items. 2006 FFRR 4.2 Supercharged Vogue SE 2007 Honda S2000 2008 Aprilia Tuono Factory |
| All times are GMT |
