Home > Maintenance & Mods (L322) > front wheel bearings
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
has anyone done the front wheel bearing change job at home or is it a garage job ???
Post #188339 14th May 2013 9:43pm
looks like a garage job unless you have a press,
http://www.fullfatrr.com/forum/topic7883.h...l+bearings ... - .- -.
Post #188341 14th May 2013 9:47pm
ebajema
Press job, mine were done recently as well. Didn't do the work myself, our mechanics did. Also replaced two bushings, the front airbags and brake discs.
Rear bearings to be done as soon as they arrive here Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #188342 14th May 2013 9:49pm
Tayas
Can you just replace the entire hub? On other cars I've just done that in the past as it's cheaper than getting new bearings pressed in. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #188344 14th May 2013 9:55pm
ebajema
This is not a "factory made" hub, like I use on my trike where you can't replace the bearing at all. This is a proper (big) bearing pressed into the hub. Replacing the whole hub is possible, just a lot (?) more expensive. MY 2010 5.0 SC Galway green and sand interior!!
Post #188348 14th May 2013 10:11pm
Deasy
I had a front wheel bearing done yesterday at an indie
The bloke told me roughly £200ish + vat
Picked the car up and the bill came to £168 inc parts labour and vat
Post #188374 15th May 2013 7:36am
I can sell you the driveshaft pressing tool...
Exactly the same as a Land Rover tool, but made of a stronger grade of steel... Thumbs Up
I had to have 5 sets made for my engineering shop to get the price right, so i have 3 sets to sell...
Price to forum members is £200 for the set...
Craig... Thumbs Up
Post #188378 15th May 2013 8:00am
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Do the drive shafts press straight out of the hub, or is there a knack? I recent had my hub and drive shaft out as 1 and the garage couldn't get the drive shaft out of the hub with a press and penetrating oil and 48hrs. Although I have since decided I will not use them again after seeing a gearbox change they done on my brothers van. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #189105 18th May 2013 10:53am
See my post above! All is explained there...
Post #189106 18th May 2013 11:01am
You will probably find you now have a knackered wheel bearing now... They don't like presses and hammers!
Post #189107 18th May 2013 11:04am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I need to change my CV boot gaiters, I think I'll just remove the hub plus driveshaft complete and try replacing them without removing the driveshaft from the hub. Going to beinteresting...
Post #189109 18th May 2013 11:06am
Not a nice job rich... Good luck Sad Thumbs Up
Post #189111 18th May 2013 11:13am
Richcl
Thanks, I've set aside a day to do it, should be long enough.... Smile
Post #189113 18th May 2013 11:18am
