![]() | Home > Technical (L322) > '07 Sidelight Lens Melting |
| Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261
Just noticed this on my new '07 S/C. Top of the lens looks like it's melted. Both sides are the same.
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
I Suspect it is heat from the cornering bulb (Extra lamp that cones on when you have nmore than 70 degrees of lock on) that has caused the damage.
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Its the adaptive/cornering bulbs heating it up too much. Are they the right spec?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
there are 2 wattages for h7/h8 bulbs, 35w and 55w ..not sure which type is in those headlights but you might have the higher incorrect wattage in.. ... - .- -.
Thanks gents. |
Yes, agreed. |
if you get canbus error free leds it'll be a straight swop.. ... - .- -.
Ta! |
PS if you can keep the old lamps let me know as i have a use for them |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Are you in for a new desk Will |
ha ha, i could just see some of my colleagues faces if i tried that as well as the 'well at least that one works at least' type stuff!!
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Well, the main dealer response to this will be interesting (has sir left full lock on whilst cleaning/ maintaining.. swapped the bulbs etc).
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Yes be interesting as new lamps is a big expense.... |
That thought had occurred to me.
| All times are GMT |
