Home > In Car Electronics (L322) > Cd changer gone 2005 54 l322 "no disk"
DTaylor
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Chawton White
Hi, first post
There is loads of things I want to do with my car but starting with the basics,
Cd changer not loading disks, changer is in the glovebox (model number xqe500201 pu-2610a)
I have looked at loads of posts in different forums, but cannot find the answer
I have an l322 2005 54plate touch screen ( I don't know what type or name of head unit this is) I have no option for tv, but I do have option for phone and sat nav (also not working)
I would like to replace this cd changer either for a different cd changer, mp3 changer or ipod/iPhone music connection, is there a plug and play alternative that will work with the touchscreen and the buttons on the steering wheel?
All this whilst keeping the radio working as when I remove the cd changer the option for radio blanks out
Thanks
Darren
Post #188559 15th May 2013 11:29pm
Vogue
Have you disconnected the battery for 30 minutes? This can clear loads of problems including suspension faults 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #188571 16th May 2013 8:01am
DTaylor
I havnt as i knew the changer was gone, i tried taking it apart to see if anything was stuck but nothing would move inside, i fancied an update anyway, cd changers seem really old tech.
I thought there may just be a plug and play out there
Post #188572 16th May 2013 8:09am
Welcome, you may be aware of Dension ipod kits? Well the only way you can buy such a thing is to purchase one through Land Rover as they have them made under licence... They are called an iPod Connectivity Kit and are around £400... They are sold for the 2007> facelift model onwards but fit from the earliest touchscreen models (as they have the same tech) I have one in my "55" plate and they are great Thumbs Up
Secondly, your DVD drive for the nav is in the boot, behind the lhs panel/door. Check for any wet in this area VERY IMPORTANT! If there is any signs (or past signs) like white staining on the ECU lids then you must get this resolved before you loose maybe all functions from your screen... Do a search on the WIKI for water ingress... Usually down to a rubber boot seal expanding in the top corners...
Craig Thumbs Up
Post #188576 16th May 2013 8:29am
Interestingly Land Rover is not included on the Denison Website at all...
Post #188581 16th May 2013 8:38am
Must have paid a bit for that exclusivity as just about every other Brand is on their website Thumbs Up
Post #188583 16th May 2013 8:43am
Yes Gaz, thats why they cost a small fortune Shocked
Post #188584 16th May 2013 8:44am
Is there a way of fitting it and keeping the CD changer unit as well?
Post #188585 16th May 2013 8:46am
Yes Gaz, they have a button in the glovebox (with a USB) you need to turn the car off switch the button and the CD if back as primary, then visa versa to go back to iPod...
The screen in the car displays all the track info too and your SW & satnav screen buttons work the iPod functions...
Craig Thumbs Up
Post #188586 16th May 2013 8:53am
Sounds very good. And the price from Land Rover?
Post #188588 16th May 2013 8:56am
Found this for Forum info:
Dension Gateway 100 iPod/iPhone car integration for Range Rover Vogue
A complete integration package to connect your iPod/iPhone to your Range Rover Vogue
The Dension iPod Interface brings complete integration of the Apple iPod/Iphone with your factory fitted stereo. The Dension Gateway 100 is our standard solution for virtually any vehicle. Providing you with full iPod control from your car’s original radio, the simple aim is to provide iPod integration without making unnecessary changes to your car’s original equipment or dashboard. Choose an iPod cradle from our accessories section for an even neater installation, or simply have everything tucked away in your glove box.
Full Integration
Dension translates CD changer messages to iPod controls and switches the iPod automatically on and off as you select/deselect the CD changer source and your iPod is charged while connected.
Key Features of the Dension Gateway 100
- Full iPod/iPhone control and charging
- 3.5mm auxiliary input jack
- Retains OEM dashboard aesthetic
- Plug and play installation/de-installation. Perfect for leased vehicles
- Control of external devices through the OEM controls
- Song information and browsing on the OEM screen*
- Wide range of accessories to extend functionality
*Text is available on either the head unit or cluster display for music information when connected to the iPod/iPhone. Please note that ID3 tags (artist, title, album) text is visible on compatible radios.
Whats Included in the Package
- Gateway 100 (GW16BM4) module for Range Rover Vogue
- iPod/iPhone docking cable (IPO5DC9)
- Vehicle wiring harness
- iPod/iPhone Extension cable (EXT2IP9 X2)
- CD Retention Kit (CDR2BM4)
- Installation - optional, please select
Post #188590 16th May 2013 8:59am
Craig Thumbs Up
Whistle Whistle Whistle [/i][/u]
Post #188591 16th May 2013 8:59am
OK I did see that but assumed that was your fitted price. I have seen them advertised for £165.... Whistle
http://www.incarhandsfree.co.uk/ipod-car-k...over-vogue
First time I have seen the very expensive mCar system while searching as well:
http://www.carcommunications.co.uk/car-acc...land-rover
Post #188595 16th May 2013 9:04am
DTaylor
Would this work with the touchscreen model?
http://bit.ly/10HFylq
Going off the product code given above
Post #188600 16th May 2013 9:15am
I would presume thats for the early non touch screen...
Post #188605 16th May 2013 9:19am
