![]() | Home > Maintenance & Mods (L322) > HELP: Strong squeaking noise from rear suspension (TDV8) |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
Probably your lower ball joint, easy way to check is to puncture a very small hole in the rubber and spray some WD40 in the hole with a straw attachment and voila it should shut up immediately, if not, put a blob on PU sealant over the hole to make it water tight and move on to the next... This is not a fix! It will need replacing, just an easy way to diagnose which part...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35709 ![]() ![]() |
defo a 'thursday top tip' that Craig.. |
Had it on mine as well, went away after the front suspension bushings were replaced (badly worn rubbers). MY 2010 5.0 SC Galway green and sand interior!!
Often comes and goes with the rain too! Water is a lube after all |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Thank you to our great L322 Guru !
Here is how to replace the front lower ball joint lads:
No worries J |
how to is in our wiki as well ..its the same as the RR.net one.. ... - .- -.
^^^Thanks, I may have found the issue thanks to you both, see EDIT ONE on my original post |
I'll place a euro on it, it's the rear lower balljoint |
I would just change both |
^^^Makes sense really.
