![]() | Home > Wheels & Tyres > 24" split rims / losing air out of bolt / manchester |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
Thought I'd reply before a few of the locals take the p15 about your huge rims! I'm guessing they are split rims? The problem is a wheel of that size has huge amounts of destructive forces placed upon it during driving and as such is more probe to failure and damage. It doesn't matter how expensive they are, we don't have roads or weather like California. You could have a hairline fracture invisible to the eye that's leaking, a dangerous thing because its only going to get bigger. People weld these up and that... In my opinion is very bad practice. You could have a poor seal on your split rim due to a slight face imperfection, air will leak through 0.10 of a mm. You could have a similar problem with a bolt hole or rim lip.
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 ![]() ![]() ![]() |
wont be easy selling 3 working wheels im thinking. thought there may have been a sealer that's better than on currently or get them refurbished. guess im just going to look for 20s |
steveyd
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Yes they will fit but the tyres are RRS size not FF size... They will fit and work but the tyres may look slim on a FF |
thanks craig, do you know if these are also split rims? as they have a not on the rim and I don't fancy going through the pain again |
No they are not split rims |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Are you sure the wheel refurb place has done your 24" wheels properly. Splitting down a set of split rims and then putting them bac together is a specialist job as you have to torque up the bols tin the correct sequence or you can over stress the wheel causing the rims to warp 56 TDV8 Vogue SE
im guessing they didn't go into that much detail no, I would like to get that one wheel fixed and carry on. would make my life easier. |
