Home > Maintenance & Mods (L322) > How to remove S/C Lower Trim/ Front Wing
pld118
Hello,
Just got car back from dealer and noticed that on front driver's side wing, the piece of square plastic/ colour coded trim at the bottom of the wing (between the wheelarch and the driver's door) seems slightly 'dented'/ pushed in.
Paintwork is fine/ best way to describe it is like a en empty plastic bottle that gets pushed in a bit.
How is the trim removed?
Hoping I can heat the piece up with a hairdryer and/ or push it back out by hand without bothering anyone else about it.
Please/ thanks
Post #188899 17th May 2013 1:01pm
Open door, look for large white or black plastic fastener below door hinge. Pop this out with a large screw driver.
You may then need to remove screws for front mudflap if you have them.
Then at bottom of side vent and edge of wing, loosen bolt to release. Will be a fiddle to refit.
Search on here for side vent removal (wiki) for images. .
Post #188906 17th May 2013 1:19pm
check this Smile
at 0.36 sec
Post #188921 17th May 2013 2:47pm
pld118
Brilliant. Cheers
Post #188975 17th May 2013 5:49pm
They just pull off if no mudflaps from door edge....
Post #188981 17th May 2013 6:01pm
pld118
Post #189039 17th May 2013 9:00pm
