Home > Wheels & Tyres > what to do with airsuspension when changing wheels
Page 3 of 3 <123
I change wheels on RR nearly every day and I know how to do it with only a few pumps off a trolley jack as explained several times. (Offroad Height)
I am not the Numpty here Rolling Eyes
Post #189347 20th May 2013 9:17am
Rambles, maybe you could experiment jacking yours up in all three modes and let us know the results...... ... - .- -.
Post #189348 20th May 2013 9:22am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
page 243 - "normal height" in my manual
Post #189349 20th May 2013 9:25am
pld118
'Rambles'.... Brilliant! Not sure about jacking a car up but maybe someone is a wind up merchant... Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
Post #189364 20th May 2013 11:02am
Rambles
rambles is rumbled......
Post #189384 20th May 2013 1:06pm
I use my bottle jack at extended height now and only takes a few pumps to get the wheel enough off the ground to pop it off Smile and thats with the MT/R's on Smile
My other car is much better for this.
Put car at full height, put jack on it at jacking point until you feel the bite of it trying to lift some weight, Set car into low/service mode, all wheels start getting sucked up into their arches and the wheel is simples to swap Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #189398 20th May 2013 1:48pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Whilst not wishing to hijack this thread (it would seem to have run its course), the jacking point is a rectangular recess to match the factory jack. My trolly jack has a cup which doesn't match the jacking point shape at all.
What do you folks use between your trolly jack cup and car jacking point to avoid and damage to the car because of this difference? Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Previously: 4.4 TDV8 Vogue Baltic Blue MY11
Post #191913 3rd Jun 2013 9:52pm
not for a trolley jack but it will give you an idea,
http://www.fullfatrr.com/forum/topic14177....cedes+jack ... - .- -.
Post #191914 3rd Jun 2013 9:56pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Don't use a random piece of wood or metal ... I did... Car fell off trolley jack and Censored the running board. Big Cry Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #191919 3rd Jun 2013 10:01pm
Baron
Top man Stan, thanks. I was thinking of getting an adapter made to fit inside the cup of my trolley jack and this info helps.
cheers. Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Post #191920 3rd Jun 2013 10:03pm
@ Baron, there is also a block with circular bottom that fits a trolley jack cup you can buy on eBay.
FWIW in all my years of jacking cars with my trolley jack I have generally used a 4 - 6" piece of 4x2 between jack and jacking point, there is enough "give" in the wood to "fix" onto both. For the FFRR I have a smaller block of wood that fits inside the jacking point to spread the load. The key is to have a good solid base on which to rest the jack, and then to get the jack in the right place, allowing it to "move" as the geometry changes. Watch the contact point as you jack up to be sure all is stable, then as soon as you safely can, get an axle stand under the appropriate place on the subframe. .
Post #191935 3rd Jun 2013 11:36pm
Baron
I've ordered one of these to fit the cup of my trolly jack.....
http://www.ebay.co.uk/itm/BMW-MINI-JACK-AD...7046382701 Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Post #191937 3rd Jun 2013 11:59pm
Page 3 of 3 <123
