![]() | Home > Technical (L322) > 04 L322 3.0td6 wont always turnover |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
It could also be the low pressure fuel pump not getting enough fuel to the front end? does it come up with any warning msg's?
alexpez23 Member Since: 01 Apr 2013 Location: Shropshire Posts: 20 ![]() ![]() ![]() |
Hi thanks for the reply but the engine doesn't turn over so it isn't a fuel issue. |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
any sort of noises from anywhere?. |
Sorry I read your post wrong, i assumed it was trying to start but just wouldn't.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
You could try greasing the gear selector cable adjacent to the gearbox.
Thanks all for your feedback but i think nicedayforit may be in the right area so i will give that a try, i will be sure to let you know how i get on. |
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 ![]() ![]() ![]() |
Hi Alex, I assume you've seen the thread that I started "Td6 Won't Start..."
elbitrevnoc - the video that you posted is identical to the 'noise' that I had. Replaced the ignition switch [supplied by Dan] and all is good. |
Just to update you, all on thursday evening i sprayed the ignition with wd40 as i was going away on friday afternoon so needed the car. Friday comes and it was just as bad, every time i tried it, it would take about 10-15attempts before it would turn over. Then saturday morning i came to use it again and it started first time, since then it hasnt missed a beat. Not sure if its coincidence or whether the WD40 had done the trick in the ignition barrel, if so what had it actually done, i will see what happens over the next week or so and keep you updated |
