Home > Maintenance & Mods (L322) > Brake Disc Change
Page 2 of 5 <12345>
dan_uk_1984
I've already adjusted it, like I said it is perfect going back but nothing going fwd so I think something is actually wrong with it. OC someone may have just driven with the HB on in the past as the HB warning light switch is broken.
Post #18986 28th May 2010 1:47pm
M44K TS
Any idea how you adjust the handbrake? Mine currently only holds when it's right at the top of the ratchet. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #18991 28th May 2010 2:02pm
dan_uk_1984
Stolen from RRUK:
RRUK wrote:
Here is the excerpt from the L322 Workshop Manual
Adjust
1. Raise rear of vehicle.
WARNING: Do not work on or under a
vehicle supported only by a jack. Always
support the vehicle on safety stands.
2. Remove rear road wheels.
3. On each rear brake:
4. Remove adjuster access plug from brake disc.
5. Rotate brake disc until access hole is in the 6
o'clock position.
6. Using a screwdriver or similar tool, turn brake
shoe adjuster until resistance is felt. Apply
handbrake several times to centre shoes, re-adjust
if required and repeat.
7. Ensure handbrake is released and check disc
will not rotate.
8. Back the adjuster off 8 notches, check disc is
free to rotate.
9. Fit adjuster access plug.
10. Fit rear road wheels and tighten nuts to 140 Nm
(103 lbf.ft).
11. Handbrake lever assembly is self adjusting and
will correctly tension cables. However after
adjustment apply handbrake several times,
release handbrake and ensure road wheels are
free to rotate.
12. Lower vehicle.
Post #18992 28th May 2010 2:11pm
dan_uk_1984
I cant get the discs off!! They seem to be seazed on like Censored . I've tried various hammers, heat and penetrating oil.
Tomorrow I'm going to try and find a supersize hub puller type thing....
Post #19023 28th May 2010 8:45pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Dan,
Did you remove the little grub screw on the front face? (I'm not 100% if there is one on the L322, but there are on Freebies and P38's - they have cross heads).
They really shouldn't be seized on. Have you backed the handbrake adjusters off to ensure the internal shoes are not binding?
I'd be very cautious about using a puller because the discs are cast and won't like being stressed in that fashion.
I bought four discs and pads today so will be doing the same when I get a chance.. Confused
Post #19027 28th May 2010 11:46pm
dan_uk_1984
Hi, yeah I did get the screw out no probs. I'm only on the front near side so far. Getting the caliper carrier off took an hour with a 2 foot bar on the ratchet handle moving one click at a time Censored
The interweb says, cut a slit in it with an angle grinder, use a hub puller, use a sledge hammer (not enough room due to the brake guard otherwise I would have).
Post #19038 29th May 2010 9:53am
Those discs look ok, you should see mine! Discovery 4 HSE
1993 90 Tdi
Post #19040 29th May 2010 9:55am
dan_uk_1984
So, any suggestions as to how to get them off? I cant get a puller that will fit.
I'm loathed to cut it off, I'm getting to the point where I'm going to have to put them back together....
Post #19062 29th May 2010 1:18pm
Have you tried an obscene amount of WD40 for a few hours and then trying?
I wanted to replace the discs and pads on my TD6 last year and faced similar issues trying to get the callipers off. I ended up booking it into the local indie garage and even they said the bolts were stupidly tight.
Cold comfort I know. Discovery 4 HSE
1993 90 Tdi
Post #19064 29th May 2010 1:23pm
McSwerve
Is there any chance of getting another jack into a sideways position where you could apply some force?
Or I was once (but it could have been the village idiot) told to put the wheel back on loose and lower it down. The movement on the hub would then help split them.
Good luck.
Post #19067 29th May 2010 2:25pm
dan_uk_1984
I tried penetrating oil overnight and a bit more this morning....
Good luck.
There's very little space in the wheel arch to get a jack or anything in there, one is limited by the fact you an only work on one small part of the disc as the rest is covered by the brake guard.
That trick works for when the wheels are stuck on and you cant get them off, but the force from the wheels is held by the studs. I have to do this regularly to get the wheels off as I suffer chronically from this for some reason.
To top it off my CV boot is leaking grease, which has then been flung all over the wheel arch. I'm covered in the stuff, and that hub grease is the worst kind ever! Seems you can only buy them as a pair = £40 Sad
So, I've stuck the new pads back in, slapped the wheels back on. I'll take it to the garage next week and get them to do it, but I guess I should buy some new pads as these will be mullered from my stepped discs. Censored
So for those who were expecting a detailed guide, here you go:
Post #19072 29th May 2010 3:38pm
daveo
hi dan, can you not take the hole hub off, removing the large nut[can check your bearings at the same time] then you would have the hub and disc in hand, may be able to apply heat better and then give it a good hammer..as you said your boot is leaking..
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #19081 29th May 2010 5:58pm
dan_uk_1984
Unfortunately there is no hub nut left in there. It's flaked away to just a mess of crap. Nothing left to get a socket on etc.
Post #19094 29th May 2010 7:51pm
daveo
dan, i had a escort years ago that had the same prop with the nut, ended up welding an old socket to it and that worked great...but this seems to be getting away from the job you started V8 facelift Range Rover Autobiography 22" wheels.
Post #19106 29th May 2010 11:00pm
daveo
dan, what about a half shaft puller, the slide hammer type, weld 2 big bolts to the disc and use the slde hammer.. V8 facelift Range Rover Autobiography 22" wheels.
Post #19107 29th May 2010 11:06pm
Page 2 of 5 <12345>
