![]() | Home > Off Topic > Roofers and small claims court. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Right need a bit of help.
Ok. It is quite conceivable for a roofer to exclude lead work from a quote. Traditionally (especially on something like a valley) lead work would be done by a plumber.
ok thanks. The lead work is the flashing between the roof slope and the main house wall. As it stands rain/water can just run down the wall and into the garage. They have added what I now know to be ldad soakers but no flashing over the top to weather proof. surelh this should be done as a standard practice for replacing a roof? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
OK, generally speaking you are unliukely to come across a situation where lead flashing would not be needed if you have a standard sloping roof which butts up to an outside wall. You "might" be able to argue that on the basis of it not being fit for purpose, i.e. they fitted a roof which is bound to leak.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Can you post a picture of the work adjacent to the wall? |
Sorry miss understanding here. I've packed in the idea of court on what you have said. I was mentioning the above to try and attain if the roof should have flashing or if we're being stupid about it. I will get some pics tonight so you can see what I'm going on about. trading standards sounds like the way to go. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
He has used the correct soakers, but obviously its not water tight without a flashing over the top.
^^^^ As above definitely needs a lead flashing with a good upstand fitted to fully water-proof.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Having built a few houses now myself (its my job after all), all the above comments seem fair, the overhang at the eaves seems small, the felt should be dressed into the gutter and supported using a proprietory eaves carier as recommended by the breather membrane manufacturer.
Thought as much. Glad to know we're in the right. When you say upstand do you mean the height from the tile up the wall the lead should go? Can you explain the bit about the ridge peak a bit more? Is there anywhere that I can see a building standard for the likes of the felt overhang and lead heights sizes etc? The more you guys mention the more I'm questioning the standard they have worked to. I would have thought the likes of the felt should be a common thing a roofer should know about????? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Yes, the height up the wall of the lead.
The tiles should over hang to the middle of the gutter, approx 2" |
Just a quick one on the felt/vapor barrier. How should if be on the roof? horizontally overlapping or vertically over lapping? getting more and more |
