![]() | Home > General > New member and owner woes |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Hello & welcome.1st port of call would be to replace the battery, do a search for the appropriate type + there were discount codes for eurocarparts as well. Best of luck. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3250 ![]() ![]() ![]() |
If this is happening whilst you are driving then it could possibly be a goosed alternator not charging. Have its output checked. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Hello and welcome to the madhouse!
Bomber County Member Since: 12 Dec 2011 Location: Dunston, Lincoln Posts: 81 ![]() ![]() ![]() |
My 07 TDV8 did exactly the same. After a lot of arsing about it was traced to the small motor between high range and low range gears. It was faulty, and was tripping all the alerts even though it wasn't being used. Put a new one in and never had the problem again. - Ad augusta per angusta - |
dalziel Member Since: 11 May 2013 Location: Harrogate Posts: 57 ![]() ![]() |
Any idea how they tracked it down so I can get a check and eliminate that as a cause? |
as far as I know it was the last in a long line of things they checked and tried. We did battery, alternator, all the usual stuff and then a specialist indy found the problem. It took a week of trying things as they didn't want to keep putting new bits on that weren't going to fix the issue. - Ad augusta per angusta - |
Anyone know an independent landrover specialist near Harrogate they could recommend? |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
If it's only doing this a motorway speeds then it'll be something to do with the suspension trying to lower itself to the motorway height, which it should do. You can stop this from happening by pushing the centre button on the suspension control switch until the lights on the button come on. This will keep the suspension at normal height and stop it from attempting to lower itself until you get it fixed.
Could be a height sensor, cheap fix too. |
The light on the centre button comes on when the chime etc. goes off so sounds a possibility assuming the car would lock the suspension if the adjustment wasn't working. Is that a height sensor problem and how is it checked? Are there 2nd hand IID tools and how much are they? Would an IID be able to check for height sensor failure - assuming it was something approaching an idiot in car maintenance terms wielding it!? |
I suggest that you contact the IID team to ask what the capabilities of the IID are in that field. I will definitely read all the fault codes.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
i doubt it..these are very useful diagnostic/configuration tools and once brought always kept.. ... - .- -. Y. O. L. O. . |
The IID Tool will read any suspension fault codes and tell you the height at each corner so, i assume, if one's missing then that's the corner to start looking at. |
