![]() | Home > In Car Electronics (L322) > Are these the plugs that i connect a Bluetooth ULF to? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
There is a pic on here showing the mic connector under the centre console, but you've prob seen this page already.........
Have you dowloaded RAVE from the link in the Wiki section ?
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
the mic plug is under the centre console very deep down, i had to take the console out on mine to find it. its under the heater ducting pipe near the passenger seat at the rear, the wires will match exactly when you find it to the roof plug. |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Thanks mate, will rip out the console ! |
Zaskar Member Since: 17 Mar 2014 Location: Oxfordshire Posts: 18 ![]() ![]() ![]() |
Hi there, sorry to come in at the end but ccfj1 mentioned about the mic cable. Are these freely available on the market or are they bespoke? Please could someone point me in the right direction as I have all the other components except the cable.
ccfj1 Member Since: 14 Feb 2013 Location: UK Posts: 32 ![]() ![]() |
The mic lead in the pic (that I posted) was bespoke. Not sure if its available form either Rover or BMW. |
It should still work if you run the connections as below ;
Do you still produce them at all ccfj1? Sorry to be cheeky? Or if not where I could get the connectors from?
The mic lead?? it will depend on what you have mate, how will you be putting the mic inputs into the 54 pin plug? |
Hi ccfj1,
Sorry, forgot to mention that I have a 04 l322 Vogue.
So the BT loom that you have has the mic input plug then?
Hi ccfj1,
OK, Can you take some pics of what you have and I'll see if I have what you need. |
