Home > Maintenance & Mods (L322) > Smouldering, Slamming, Rumbling, Steering
pld118
Hi,
There is a burning smell from the wheels of our S/C after use. On short and long runs but I stress the car is not at all being driven hard (now had car back from a 2 week stay with main dealer for 7 days/300 miles).
Any ideas please?
Thanks
Post #190503 25th May 2013 5:59am
ebajema
Sounds like another classic SC problem, the brake calipers being stuck. Normally the rear calipers suffer this problem and most of us have had them changed. Sometimes it is accompanied by strange vibrations and "holding back". I initially feared a gearbox issue but then noticed the smell and hot rear disc.
Try to track it down to one of the wheels, go for a little drive and then stop and hold your hand close to the discs to see which one seems hotter than the other. That is the one that needs changing. Best it to change both rear calipers, they relatively cheap to change out (I paid 70 Euro each for exchange of the old ones).
The front calipers (Brembo) usually seem to be fine. MY 2010 5.0 SC Galway green and sand interior!!
Post #190512 25th May 2013 7:35am
pld118
Thanks/ v much.. Will let you know later
Post #190515 25th May 2013 7:41am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I've had smoke pouring from my calipers before, plus a very bad shimmy through the steering wheel. At least your mpg will go up a wee bit once fixed Thumbs Up
Post #190517 25th May 2013 8:09am
pld118
Would you please be able to elaborate as to how the steering shimmy manifested itself (main dealer -1week ago - replaced Servotronic valve and was asked to/ said they did fully inspect/ callipers, discs & pads and only query they found was to clean front brakes. I have queried that steering did still feel something small amiss too)?
Thanks
Post #190519 25th May 2013 8:33am
Mr Tee
Violent shaking through the steering wheel, made the car undriveable . Never had a car react like that due to sticky caliper, Although never had such a heavy car either. Just go for a wee run as described above & touch your wheels when you pull over, it will be very obvious if any are stuck, as the wheel will be hot.
Post #190548 25th May 2013 11:53am
pld118
Post #190567 25th May 2013 1:54pm
pld118
There is no smoke nor violent vibration through steering. Took car for a reasonable drive and the smell is coming from front offside wheel. None of wheels were particularly hot. As mentioned, car was only given back by dealer a week ago and they had done some cleaning of front brakes after being asked to specifically check all car's callipers, discs and pads to reassure me they were not in need of near future replacement following other issues I had that called into question the effectiveness of selling main dealer's pre sale multi point inspection.
Will contact local main dealer...
Post #190608 26th May 2013 6:14am
Just a thought, might it be the fuel burning heater kicking in? Can smell a bit when lit, and will still kick in on these cool mornings to help warm the engine. There is nothing that can't be fixed with a hammer😜😜
Post #190621 26th May 2013 8:30am
spanner
on a SC ?
Post #190624 26th May 2013 9:08am
Embarassed
Dont sc have a heater? Ah well another reason to buy a tdv8... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #190626 26th May 2013 9:17am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
My SC has the heater. Optional extra Thumbs Up Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #190642 26th May 2013 11:57am
pld118
Without knowing options, how can you tell it's fitted please?
Post #190654 26th May 2013 1:23pm
you will have the timer option on your screen menu Ryan. ... - .- -.
Post #190656 26th May 2013 1:59pm
And a big silver Webastro box with an exhaust on the inner wing... Thumbs Up
Post #190658 26th May 2013 2:02pm
