Home > Technical (L322) > Passenger side mirror stopped dipping
dirtyharry
For some reason, the passenger side wing mirror has stopped dipping when I select reverse. I have checked that the mirror selection switch is set to "driver" side, so I know that's not the problem. I can see it is dipping a little bit, but doesn't dip fully to enable me to see the kerb, as it used to.
Anyone have a fix for this? Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #190609 26th May 2013 7:05am
GreenBlood
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Have you tried adjusting it down so you can see the kerb when it is in the dipped position? If you don't get stuck then you are not trying hard enough.
2012 FFRR TDV8 Westminister
Gone: Def90 2.8i, Def110 2.8i
Gone: RRC 2-Door and 4-Door, 2007 FFRR TDV8 Vogue
Gone: Aussie Spec D1 V8, D2 V8
Post #190614 26th May 2013 8:02am
mpirie
I had my passenger mirror in bits last week, it's possible you have an obstruction stopping it moving so a stripdown may be in order?
Mike
Post #190618 26th May 2013 8:14am
Could just need the dipped position re-entered in the seat memory.
Post #190620 26th May 2013 8:27am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I wonder if there are sensors or something inside the mirror. I set mine up when I first got the car and no matter what I select or set or store, my passenger mirror does move when I engage reverse but just moves in small amounts all over the shop. Looks like it's having a fit of some sort. Kinda twitching all over the place.
I just ignore it these days but should fix it really. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #190622 26th May 2013 8:59am
this might help,
http://www.fullfatrr.com/forum/post162506.html#162506 ... - .- -.
Post #190627 26th May 2013 9:20am
dirtyharry
Thanks for the info guys. It seems very hit and miss at the moment - it didn't work yesterday, but this morning it did. And it still dips ok if I adjust it manually, so there's no obstruction that I can see.
Must admit, I wasn't aware there was a memory setting for it Embarassed so I'll try a re-set and see if that works. Cheers
Greg
Previous vehicles:-
Post #190790 27th May 2013 12:51pm
Battery reset will help Thumbs Up
Post #190844 27th May 2013 9:53pm
dirtyharry
Thanks Craig - will give it a go Thumbs Up Cheers
Greg
Previous vehicles:-
Post #190937 28th May 2013 2:13pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
Did you sort the problem?
If you select reverse and it doesn't move, switch the mirror selector button next to the window switches and it will start moving down! Thumbs Up 2009 TDV8 Vogue SE - Bonatti Grey
Post #192248 5th Jun 2013 11:06pm
dirtyharry
Thanks for the tip Mark, but I knew about the mirror selection button needing to be set to the right, and it always is. So that wasn't the source of the problem.
I've also tried the memory setting by dipping the mirror and pressing the memory button on the seat, but that just made the mirror stay dipped permanently Rolling Eyes
Sometimes it dips, sometimes it doesn't, but that just adds to the annoyance of the mirrors not folding out either when I press the remote to unlock the doors (I've got the Intravee set to unfold them).
And I'm still having battery problems, so that probably isn't helping. Big Cry
All in all, yet another frustrating foible with the FF!! Laughing Cheers
Greg
Previous vehicles:-
Post #192260 6th Jun 2013 7:16am
Mark.abersoch
It was worth a try. I didn't know about it for a while.
I'm thinking out loud now and could be way off the mark Confused but could it be down the the reverse switch not working if they do have such a thing on these. Just a while back on a audi my reverse lights stayed on whilst driving and the parking sensors where also activated due to a dodgey switch. I'm sure someone with the proper knowledge might be able to say more about this.
Worth putting it out there tho. 2009 TDV8 Vogue SE - Bonatti Grey
Post #192271 6th Jun 2013 8:10am
Is the adjust switch on the right side? Moving the adjust switch over stops the dipping (thanks Stan)......
Post #192274 6th Jun 2013 8:26am
dirtyharry
It would make sense that there is a switch or a sensor on the gear-shifter that triggers when reverse is selected and that then dips the mirror. But no-one has come up with a cure to fix it, if indeed that is the problem! Cheers
Greg
Previous vehicles:-
Post #192276 6th Jun 2013 8:29am
dirtyharry
Gaz.... already covered off in my previous posts Wink Cheers
Greg
Previous vehicles:-
Post #192278 6th Jun 2013 8:32am
