![]() | Home > Maintenance & Mods (L322) > Dropped spanner beside battery tray, where will it come out? |
I lost one down there on my car too |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Done it too... I slackened off the battery tray (battery out) enough to get my hand down and have a fish around. Got it but it was not easy...... Previously..
Pity spanners were not alive as you could use a worm on a hook or similar |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
10mm socket under mine........
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
Front nearside wheel arch liner out. Not as bad as it sounds. Remove wheel, about half a dozen plastic 10mm nuts and a few other screws if you have mudflaps. Takes about 30 minutes.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
Any chance you could tie a magnet to a piece of string and go fishing? I have one of those aerial extending magnet that has rescued many a tool (including the owner) ! ![]() Mike |
Good thinking mate I'll have a go with the magnet pen tomorow. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Have done this myself! |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
I did the same but took the battery tray out and reached down inside as the battery was out anyway (I was changing it). Wheel arch liner gets to the same area but I couldn't be bothered fighting with it and taking the wheel off to get in there. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Its possible to remove the arch liner without taking the wheel off and fish around the fbh for it. There is nothing that can't be fixed with a hammer😜😜
