|  | Home > Off Topic - Other Cars > Austin Allegro - 40 Years Old |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848      |
 So the Allegro is now 40 years old.
|  28th May 2013 7:26pm |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848      | Here's a video on quality control at BL. Notice David Suchet working as a designer before he became Poirot. Loads of other familiar faces also.
|  28th May 2013 7:29pm |
| kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182    | Brings back some memories.......... my grandfather had a succession of these, he had a real working man's pub in Bathgate, West Lothian where one of the BL factories was -he always maintained him buying them helped put money in the BL workers pay packet, which in turn ended up in his till...... Used to give my dad a real hard time for buying that german rubbish ie Mk1 Golf. After the last Allegro died (didnt take long!)it was an Ambassador and then two Montego's. Happy days..........! | ||
|  28th May 2013 7:50pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | ^^^^^ and i'll bet the mk1 golf outlasted them all, and is now an appreciating classic.......
|  28th May 2013 8:05pm |
| kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182    | Jees Fiat 126.......... had forgotten them, when I lived on Islay our Gaelic Teacher had a red one of these, she stayed up the road from my folks and was quite fond of her drams - put if off the road into a ditch one night and it literally couldnt be seen as you drove past - took a few days to be extracted and probably sustained more damage being taken out than it did when it went in. Need to stop this now, that was over 35 years ago........... | ||
|  28th May 2013 8:28pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | For some reason he decided that it was wise to buy both a fiat 126 and 127 at the same time.
|  28th May 2013 8:32pm |
| tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283      | Weirdly just saw an immaculate looking white estate a mile away. Looked really nice given the time thats passed.
|  28th May 2013 9:08pm |
| A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973    |
 Ahem.
 if you don't mind. Graham ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey | ||
|  28th May 2013 9:55pm |
 I will confess I've never driven one. Mine had the round steering wheel. I can only think that as you loosely grip the wheel as it self centres when you come out of a corner you'll get the the corners of the square (I know they were rounded) going through your hand. Wikipedia says it 'allowed extra room between the driver's legs and the base of the steering wheel'. Well, not if you're going round a corner. Why was it a good idea, and if it was such a good idea why did they abandon it, and why aren't all cars equipped with square steering wheels? Sorry 'quartec' steering wheels. | ||
|  29th May 2013 9:01am |
| Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912      | I learnt to drive in one and a maxi
|  29th May 2013 9:06am |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964      |
|  29th May 2013 9:15am |
| tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283      | Well the original theory was that if you were going along a straight road with your hands at say 3 and 9 then small movements of your hands wouldnt have a huge effect on the wheel because your hands are closer to the centre point hence smoothing out the drive.
|  29th May 2013 9:35am |
| Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261      | Apparently, the quartic 'wheel came about just before launch when the BL MD's wife sat in an Allegro and complained there wasn't enough room between her legs and the 'wheel. So they flattened it and that was that.
|  29th May 2013 11:28am |
| campaj1 Member Since: 22 Oct 2012 Location: Cheshire Posts: 729    |
 one big excuse of a video! think of the work Mercedes were doing at the same time with the W123! A time best forgotten. They screwed up big time. They should have capitalised on the Mini brand, bringing out a raft of similar cars in different sizes. They should have developed the Mini itself more too: a new model was needed by at least 1970, and I discount the hopeless metro, which basically eradicated all of the good points about the mini (nippy handling, compact size, cool image) and retained all of the bad points (asthmatic A series, Rust problems, sloppy hydraulic suspension, sparse interior) creating a truly terrible car. The Allegro was unfortunate; clearly too much time was spent looking at the Alfasud when a far simpler, more elegant design could have been developed with a proper hatchback and rubber cone suspension saving cost and reducing mechanical complications. Having said all this, they trusted Issigonis for too long, the Landcrab and Maxi were an extension too far of his designs and as a result they failed to sell. N eed I mention the Marina, which was just a lazy effort; they should have just killed off the Morris brand there and then, rather than tarting up the ancient Minor. And then we come to MG, which should have died by the early 70s, the cars were just an embarrassment by then. The TR7 should not have been built in Liverpool, and god knows it shouldn't have looked the way it did. All they had to do was build a modern sports car that the Americans would take to. In fact A TR6 with a Rover V8 and updated styling could have worked; the chassis was dated but worked fine. Then we look at Rover; the SD1 was a brave effort, but quality was simply not good enough, so they should have handed the mantle over to Jaguar to develop the XJ, and spent more on development of the Range Rover and the Rover V8 for other cars (Stag). Oh yes and the Princess; they needn't have bothered. More factories should have been closed to ensure survival, and defunct brands flogged off (Wolseley, Riley etc) so there.   | ||
|  29th May 2013 11:54am |
| Posting Rules
 cars and now i bought a FF?????
