Home > In Car Electronics (L322) > Disable interior alarm sensors by key fob??
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Folks, besides going through the car menu system to disable the interior sensors each time i park up so I can leave my dog and lock the car without him triggering the alarm, is there any other way to do it? On my old disco you just needed to press the remote twice in quick succession but that doesn't work on a full fat.
Cheers
N.
Post #191256 29th May 2013 11:47pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
With miine you lock it with the remote then press it again and a wee red light comes on on the dash for a second. The dog is fine in the car then.
What I dont know is how to do it when the battery in the remote is flat and you lock the door with the key
Post #191257 29th May 2013 11:50pm
Fleagle_UK
not sure why the difference then. Question Question
As I say, when I hit the button twice, the alarm still triggers if interior movement is sensed.
The owners manual says that double pressing the remote just deadlocks the doors.
cheers
N
Post #191284 30th May 2013 9:52am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
With the key turn the key in the drivers door lock twice within 10 seconds towards the rear of the car
With the remote press the lock button twice within 10 sec.
Page 16 owners handbook under locks and alarm
Post #191301 30th May 2013 12:35pm
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Mine is a TDV8 07 and to put it into no internal sensors mine says lock once as normal wait a second or so and press lock again. No sound from the car but alarm has never gone off ever when set like that with the dogs in the car. It is not quick succession for mine but a moment in between both. Good luck
Post #191321 30th May 2013 3:14pm
stu
i am the same on both my TD6 and TDV8 i press the lock button twice and i leave the dogs in the car no problem!!
the only other thing is that both my car alarms have been knackered without me knowing!!...lol.. Shocked Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #191342 30th May 2013 6:19pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
page 29 in my manual says -
If superlocking is required, but NOT interior
space protection, press the lock button on the
remote control twice within 10 seconds (or turn
the key in the driver’s door lock towards the
rear of the vehicle, twice within the same time
period). Allow for a two-second delay before
pressing the lock button a second time.
- oh and it works!
Post #191366 30th May 2013 8:16pm
tomthevet
On a slightly different note, can you turn off the alarm with the key in the door?
T
Post #191381 30th May 2013 9:15pm
Fleagle_UK
right... I'm going to have a good play (coooeerrr Shocked ) with my locks
but pretty certain that twice (either in quick succession or within 10 seconds) makes no difference to the interior sensors.
In fact page 12 of my owners handbook explains the single or double locking using this method but nothing about disarming interior sensors.
I can only assume it's a model year thingy. shame really as it seams a faff to have to go through the car menu settings (page 14) on the dashboard every time I want to lock the car with the dogs in. Double pressing the key fob is much easier.
Rolling Eyes Rolling Eyes Rolling Eyes
Post #191386 30th May 2013 9:50pm
ahebron
New Zealand
You should also disable sensors when you take your FFRR on ferries or transporters.
I did both the other week.Embarassed
Adrian VW Amarok 2014 Highline auto
Post #191390 30th May 2013 10:22pm
Andy
You'll know if its worked - the red light on the mirror will stay lit for around two seconds. That's what mine does. As has been said- arm the car normally, then press the lock button again and you should see the above.
Post #191514 1st Jun 2013 7:53am
Fleagle_UK
Nope Sad Sad No amount of double pressing has got this to work. Only going through the vehicle settings on the dash board TFT display.
Does any one else with. 2011MY onwards have the same problem? Or am I still missing a trick?
Can a dealer enable this I wonder Question Question
Post #191649 2nd Jun 2013 8:00am
Fleagle_UK
Finally an answer.. and important for 2010 onwards owners...
well, I have the official answer and its quite opposite to what you may logically think.
It's also important for 2010 on owners who may not have realised they are not locking their car properly. Shocked Shocked Shocked
Contrary to pretty much every other alarm remote and car on the face of the planet. Pressing the lock button on the key fob ONCE only partially protects the car. ie NO internal sensors and NO interior deadlock.
To FULLY lock the car (assuming no kids/dogs in) you have to press the key fob TWICE. This deadlocks AND arms the interior sensors.
So, like most people I suspect, I had been leaving my car only partially protected by pressing the fob once when it should be twice (contrary to earlier models (and most other cars!!))
hope that helps.....
N.
Post #191805 3rd Jun 2013 12:07pm
MML
Never tried it, but I think it's the other way around... Wink MML
Post #192037 4th Jun 2013 5:45pm
i think you may be right MML... ... - .- -.
Post #192038 4th Jun 2013 6:14pm
