Home > Maintenance & Mods (L322) > rear drop links replacing
Googsy
I want to replace these as it was noted at last service there was slight play in rears .As they are cheap I thought I would replace. Also going to replace fronts. Has anyone replaced rears as dont seem as easy to do as fronts. If so any tips advice etc? Thanks. Also once done what effect on handling will this have apart from less lean in corners?
Conor Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #191721 2nd Jun 2013 8:55pm
Rear drop links not difficult at all, but can be a bit tricky to stay on the flat with a spanner and get access with a ratchet.
Check out my howto in wiki (rear suspension dismantle & rebuild)
Having done it (and replaced everything else at the back) can't say I noticed any difference, however changing the front drop links sorted out my wobbly knocking noises that I thought were coming from the back .
Post #191722 2nd Jun 2013 9:04pm
Googsy
Thumbs Up thanks Joe. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #191728 2nd Jun 2013 9:21pm
Googsy
on the front link noticed at the top where the rubber is its not flush it sits outward which cant be right hence my reason for doing fronts. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #191729 2nd Jun 2013 9:24pm
