![]() | Home > Technical (L322) > S/C Failed to Start - Electrical |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Coincidence? Fate? A sign? I'm not sure....
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I'd say it really is that simple, get yourself a new battery, and if valeting, and putting a drain on the battery for a long time, then put it on charge.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
i agree with David that its the battery..if its the original one then you have done well and if its already a replacement then normally 3 years is generally the duration for these...i'd rather it go now than in the winter... ... - .- -.
Thanks gents! |
Manually turn off the lights when valeting.... |
Good idea. |
^+1 100ah will be fine. |
My battery went again after 2 years, in a warm climate with little "long term" drain. Batteries are not what they used to be in the old days |
i agree Eugene, mine went after 11 months and that was a 110amphr jobby as well.. ... - .- -.
Green Flag chap has been and she fired straight up with a jump lead. So that's good.
you can get leds in different colours like blue and [i'm pretty sure] warm white... ... - .- -.
Hi,
Thanks Ryan. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Not supprised you cant jump a ff with a set of leads bought to do a mini.
