Home > Technical (L322) > Air con question
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Air con question
Hi there, I start my vogue up, if I turn the fan speed up to first light the auto light comes on the knob, is this normal? If I try pressing the knob to turn the light off the round light (second light) comes on? If I press my air con button it's sometimes lights up and sometimes doesn't cant really work out when it works and doesn't! But doesn't get cold for sure! After reading some posts in guessing ill get it re gassed to Start with! Also if I press the max button the air con button somtimes comes on but still isn't cold? The centre vents are set to cold and heat on both knobs are set to 16?? Any help in enlightening me would be great Smile
Post #191924 3rd Jun 2013 10:17pm
You need to gas it , make sure they tell you how much comes out compared to how much they put in it might tell you something . 2008 MY Supercharged
Post #191925 3rd Jun 2013 10:20pm
Jammer600
Ok cheers, kwic fit the place I'm guessing by the past posts?
Post #191927 3rd Jun 2013 10:23pm
One of the cheaper options, but doesn't necessarily mean they know what they are doing! .
Post #191934 3rd Jun 2013 11:27pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
I am pretty sure the first light signifies the system is on.
The second light 'Auto' when on allows the car to adjust the airflow to automatically achieve the temperature set.
eg set 16 degrees press auto, both lights come on - car will try its best to achieve 16 degrees using all the settings at its disposal.
If you override the 'auto' feature by pressing one of the three buttons to tell the system where you want the airflow; maybe the downwards setting for feet, one of the lights in the button goes off as you've turned off the 'auto' function.
All the above is how my system works and generally how all cars with 'climate control' work.
It also does sound like you need to have the system checked and re-gassed.
A good air-con service should remove and weigh the remaining gas, vacuum test the system and re-fill the gas and compressor lubricant.
Hope this helps.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #191943 4th Jun 2013 8:23am
Re: Air con question
Everytime you press the "auto button" the AC light should illuminate as that is the default programming... If the AC light does not come on every time then you may have further issues to resolve after the re-gas...
They also cannot re-gas it if the light does not come on as the system needs to work whilst final filling Thumbs Up
Post #191947 4th Jun 2013 8:43am
Jammer600
Thanks, I got in the rr to come home and the system was on auto straight away, the a/c light came on, drove not even 50yrds and it went off again? Weird! If the blowers are flat out(full speed) and I press the a/c button i can hear the speed fluctuate but no light?
Post #192039 4th Jun 2013 6:16pm
Then i would say you need to sort that issue out first... Maybe your heater panel playing up?????
Post #192108 5th Jun 2013 8:01am
Jammer600
Ok cheers, anything I can do about it? When I get in the car literally I can here a gurgling behind the glove box, I checked the a/c fuses think three ish? One was 30a when I took that our the gurgling stopped put it back in as it was fine, started up again?
Post #192112 5th Jun 2013 8:15am
