Home > Technical (L322) > Indy diagnostic recomendations
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi all
I'm in the market to find an Indy or someone with an auto logic or similar that can program brand new ecu units. I have a brand new LCM 4 module and need someone to program my vin and mileage data in then I can do the rest using my fault mate.
Any one know any garages or individuals that can help around the Manchester/Cheshire area?
Matt
Post #193771 12th Jun 2013 9:50pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
I know of one on the Wirral if your willing the travel that far. He has the full autologic kit.
Thanks 2009 TDV8 Vogue SE - Bonatti Grey
Post #193772 12th Jun 2013 10:02pm
Rotorboater
Deleted
Post #193795 12th Jun 2013 11:28pm
mattstevenson2005
Anybody around Manchester willing to do this?
Matt
Post #194486 15th Jun 2013 8:47pm
Im surprised your faultmate cant do this.. Have you asked BlackBox as its meant to be a unit thats just as good if not better than an autologic as its more specific??
If that fails how about Landranger stockport for a try as they charge £20 per session usually and shouldnt take long to do that that you require Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194500 15th Jun 2013 10:24pm
mattstevenson2005
The fault mate is brilliant but because I have the single VIN version I can't access units that have no VIN number assigned. Also have spoken to black box about this in the past and they can't be sure that it would work correctly if they try and program the VIN and mileage data as its a one time only program I want to make sure the unit is initialised correctly. I can use the faults for all the other programming of the LCM module just not the VIN and mileage data which is a bit of a pain!!
Have just sent an email to landranger Stockport so will wait to see what they say.
Thanks
Matt
Post #194524 16th Jun 2013 9:10am
A1 landrover were very good but I'm not sure what equipment they use.
Post #194535 16th Jun 2013 9:49am
