Both front ARB Drop Links now DIY replaced.
Land Rover describes the part as a Link Stabiliser Bar, Part No. LLR030047 (I paid £40.82 incl VAT plus extra for prompt delivery for a pair of genuine LR ones - similar to that pictured below - from site sponsor Duckworth Land Rover):
Once the car was locked into off road height there was no need for me to remove any wheels or use any supporting jack in order to release tension, remove or replace the drop links.
As per the below linked thread, I had great difficulty in removing the lower arm Hex nut on the driver's side. No such difficulties were encountered with the passenger side. On both sides, once the old link arms were removed, the new ones were a simple fit by hand:
http://www.fullfatrr.com/forum/topic27572....t+splitter
If I was going to do this job again, I would ensure that I had the following tools on hand before starting, just in the case of any seized nuts:
* Socket set (preferably 6 point sockets as 12 point sockets can spin under heavy load, shearing the head of a seized bolt)
* Breaker bar
* 18mm spanner
* Wirebrush
* Penetrating fluid (e.g WD40)
* 'ProGas Formula A' anti seize spray or equivelant.
* DIY sized blowtorch
* 'Merceded Benz Sprinter Jack' sized wheelbrace
* 18mm Nut Splitter
* Junior hacksaw and plenty of spare blades
* Small lump hammer and cold chisel plus a thin flat headed screwdriver for chiselling
* Metal file
* Adjustable hand grips
* Grease/ anti seize grease
