![]() | Home > In Car Electronics (L322) > dash lights HELP |
W88DY M Member Since: 15 Sep 2011 Location: liverpool Posts: 116 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
how did these lights appear?
Other question is how old is your battery as that would be the next most likely cause... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Yes done the full lock to full lock, battery is only 6 months old
could be,
Thanks stan ill have a look. I'm going to book it in today to see what's what
First check is making sure charging voltage and current are within the "normal" range and the battery is actually still OK. Even new batteries can fail from time to time. MY 2010 5.0 SC Galway green and sand interior!!
Can low voltage make these lights come on? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
The two lights on the right are brake related, one is the Emergency Brake assist and the other is an ABS one, which as you know normally extinguishes after ignition.
If It is my battery and I charge it will this clear the lights?
Check voltage while running
Yes it only goes on short trips. This might sound stupid but how do I check the voltage
On slightly newer cars with the touch screen sat nav you can get into a secret diagnostic menu via the screen and see real time figures, I can't recall if or how it is done on the older cars though. (Known as the 753 hack)
there's this for the 2002-2005 navs,
