Home > General (L405) > L405 'sloshing' and 'gulping' noises from fuel tank - Advice
Page 2 of 3 <123>
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
3.0 V6
Post #192205 5th Jun 2013 5:37pm
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
The only little noise I have sometimes is after starting the car, there's a little bump coming from inside the trunk, comes and goes once, that's it!
By the way, when you lower or lift the car do you get an "air" noise from around the backseats air control unit as well?
JJ
Post #192208 5th Jun 2013 6:32pm
fairwx
I have this noise also, it is a "clunk" always 5-6 seconds after starting the engine from a longer standstill. Don't get it in Start/Stop restarts.
And yes when the car lifts itself up, I have a hissing from the rear seat area. You can hear it also when the engine if off and you ask the car to lower itself (ignition on).
Here is the list;
Moonroof rattles
Soft close tempremental on passenger door, drivers side
Front passenger seat bolsters don't work at all
Sloshing from the fuel tank when above half full, clearly audible
"Thud" when starting engine, from rear
Brakes squeaking on light pressure
Clicking from electronics bay in drivers side boot area (where rear fuses are) when systems are being started/stopped (audible when engine off)
Bit of a vibration between 1200 and 1700 revs under heavy load, slowly getting better as miles are added
Hissing from compressor/system when air suspension active
It is going back next Thursday.
Post #192221 5th Jun 2013 8:06pm
Java Jungle
Please let me know what they say about the "clunk" from the trunk. Might be normal, also the "hissing" from the rear seat area.
Have one rear door that sometimes doesn't soft close as well and the squeaking from the brakes on light pressure. That's about it.
Guess the "sloshing" from the fuel tank is only for the 3.0.
JJ
Post #192387 6th Jun 2013 6:13pm
fairwx
Car went in early after the rear view mirror fell off on Sunday.
The "clunk" is normal - caused by Air Compressor. SSM 64937
With the fuel sloshing noise - every L405 in the dealer does it, dealer agrees it's not good enough so at least that is a start.
Currently waiting on the rest.
Have been given a blinged up L405 (the demonstrator) for a week.
Post #193274 11th Jun 2013 7:46am
Java Jungle
Thanks fairwx, good to know that the noise in the trunk is normal...
Keep us posted about the other problems Thumbs Up
JJ
Post #193404 11th Jun 2013 4:14pm
fairwx
Air suspension 'hiss' / air noise is also "normal" - as apparently they have placed the valve under the passenger seats.
The lead technician at Guy Salmon seemed to think fixes for both are on the way as lots of feedback has been filed to LR on both issues. I suspect noise insulation on both needed.
I was also told he checked the rear passenger side body panel from the inside (the one that flares out and then back in to form the "boat tail" rear.
If you remove (or get the dealer to) the boot/trunk carpet clad panel on passenger side(the one with large, long vent and 12v socket) you will see a void where the bodywork flares out over the rear wheels. This should have foam noise insulation present so you cant place your hand in the void towards the front of the car.
Mine and some others are missing this insulation. the symptoms are simply more noise into the cabin from rear seat area.
Post #193422 11th Jun 2013 5:48pm
campaj1
still no transmission failures, so it ain't all bad Laughing
Post #193435 11th Jun 2013 6:49pm
Phil.
Right decision to stick with my silent MY11 for just a bit longer.......... Smile MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #194630 16th Jun 2013 10:14pm
campaj1
^^ true, but that comment is only ever going to provoke folks who have spent the price of a house on this car Laughing Whistle
Post #194635 16th Jun 2013 11:05pm
Phil.
You're right, it was a bit of a wind up comment. No malice intended.
Seriously though, has anyone with a L405 been able to try their FBH yet? Is it switched on for more than the inadequate 17mins that the MY11 onwards operate for? My MY07 used be on for 30mins and was very toasty as a result, but then often it wouldn't start. Some of the compromises of a RR owner Wink MY23 D350 HSE
Post #194698 17th Jun 2013 12:29pm
Java Jungle
Can't tell you, dont have it on mine.
So far I had no problems besides the lower tailgate... that has been fixed and works perfectly now. Mind you only have 5000KM done with it but keeping my finger crossed Laughing
JJ
Post #194729 17th Jun 2013 5:05pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
My FBH was very effective in March and as a bonus you can also include the front and rear heated screens in the programme. Because it worked well I didn't take any notice of the time it was on for. Remind me when it freezes in August in UK this year. 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #194821 18th Jun 2013 8:43am
Phil.
Including the front and rear heated screens with FBH is impressive. Hope it still starts once the battery is a year old! Or have LR finally implemented a dual battery system on the L405 ensuring one is always charged for starting? MY23 D350 HSE
Post #194823 18th Jun 2013 8:47am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
2 batteries on L405 SDV8 and V8 Far to many gone...
Post #195370 20th Jun 2013 6:20pm
Page 2 of 3 <123>
