Home > In Car Electronics (L322) > Should door mirrors auto fold at locking?
Simple1
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
Should mirrors fold when you lock the car or is this a feature in later cars? Mine is 2009. Wondered if it is a switchable function as I am sure my 2002 Vogue did this.
Post #194809 18th Jun 2013 7:12am
pld118
Re: Should door mirrors auto fold at locking?
I think the key can be programmed to do this/ doubtless someone will confirm or correct me...
Post #194814 18th Jun 2013 7:42am
this feature is not available afaik..
edit.....from 2010 it is apparently... ... - .- -.
Post #194820 18th Jun 2013 8:42am
pld118
Embarassed
Post #194832 18th Jun 2013 9:18am
ebajema
I have played around with the settings using the Faultmate and indeed, not available on MY2006 and older. Not sure about the newer models, I will have a look later to see if I can find the option.
I do think that some people using the Intravee have been able to activate it. MY 2010 5.0 SC Galway green and sand interior!!
Post #194847 18th Jun 2013 10:30am
if the feature isnt there in the first place [original equipment] then it cant be activated.. ... - .- -.
Post #194863 18th Jun 2013 11:26am
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
you can get that feature if you have an intravee, Thumbs Up my 54 vogue does it on every lock, all you need to do is turn it on in the functions on intravee.
Post #195056 18th Jun 2013 11:24pm
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I would love to have this option Thumbs Up
excuse my ignorance but what is an intravee Question
Post #195058 18th Jun 2013 11:45pm
RR2008HSE
Intravee - computer/code reader thingy that can communicate with your car. It can be used for diagnosis, software updates, and editing personal preferences on your car (e.g. Day time running lights, auto lock on engaging drive, etc).
Post #195065 19th Jun 2013 4:43am
Muttley
Than you for the explanation Thumbs Up sounds expensive Smile
Post #195069 19th Jun 2013 7:18am
Not THAT expensive, Dave. Thumbs Up
Crucially, Intravee works only on early BMW-based FF's and not on the later MOST system that you have on yours. Si. <This is my name.
Post #195072 19th Jun 2013 7:46am
SteveMFr
Site Sponsor
Actually, the Intravee's main purpose is to connect an iPod / iPhone to the non-touch screen infotainment system (<2005). Despite the fact that it was made for this purpose - its function and design allowed it to perform other tasks (such as auto-folding easily and the manufacturer added these functions to later firmware. (It can't be used for diagnostics, updates or changing the car's configuration - that would be either our IIDTool, BBS Faultmate, or a professional system Wink ).
It was manufactured by a small co called Intravention UK - who's founder and proprietor died rather suddenly and unfortunately last year - so if they are still available new, it's only NOS. They turn up on ebay regularly, tho.
LR never saw the need to have auto-folding on lock, and unless your 02 had an add-on module to enable auto-folding, it did not do this. This function was also never programmed into the BCM SW - so it can not be activated by editing the CCF (car configuration file) with a diagnostic system. The only way to make it work is through an add-on module. Unfortunately AFAIK no add-on modules exist for RR's 2006>. The CAn protocolls were changed and earlier systems such as the Intravee do not work on later vehicles.
We were thinking about doing something along these lines - we already have a small module that fits the hardware requirements perfectly...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #195101 19th Jun 2013 9:57am
Muttley
Big thanks for the explanation , so basically for my 57 plate Rodney that is an 08 model this is of no use to me at all , I hope i read that right Thumbs Up
Post #195228 20th Jun 2013 12:54am
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Talking of running lights should my 02 model have light sensitive headlamps? I have auto rain sensitive wipers and I thought these came as a package?
Can anyone verify? 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #195241 20th Jun 2013 7:02am
normally the two go together..have you an auto setting on the light dial.. ... - .- -.
Post #195243 20th Jun 2013 7:15am
