Home > Technical (L322) > battery drain?
STEV8
England 2005 Range Rover Autobiography 4.4 V8 Java Black
battery drain?
going away for a couple of weeks-battery drain likely?if so can i lock the car without activating the alarm?any suggestions welcome 05`V8 AUTOBIOGRAPHY
Post #193794 12th Jun 2013 11:24pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I don't think so. I think there is a way to deactivate the passive inside (maybe double click remote from memory, but handbook will say.
You can get a solar battery saver that sits on the dash (plugged into lighter). Unless your in the garage! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #193806 13th Jun 2013 6:14am
You could disconnect the -ve terminal on the battery and then lock the car manually assuming your drivers door lock works ok.
If your battery is ok you would then have a fully charged battery when you come back to the car after your hols. Thumbs Up
Battery isolating switch makes this even easier.
You would need to do the steering wheel lock to lock after reconnecting the battery.
Post #193827 13th Jun 2013 9:05am
dirtyharry
I don't use mine much so I'm going down the solar powered battery saver route, as I'm sick and tired of finding an almost flat battery when I do come to use the Censored thing! Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #193829 13th Jun 2013 9:23am
Another vote for the solar battery charger. Plug it into the boot accessory socket as that's on a permanent live. Si. <This is my name.
Post #193832 13th Jun 2013 9:29am
dirtyharry
Just a case now of deciding which one gives the best results! This one has a good review on Amazon:-
http://www.amazon.co.uk/Solar-Briefcase-Ba...EXOF1IUXXQ
However, it is sold under various brand names (including Gunson, who make good quality strobe timing lights) and the price varies between £18-£30 depending where you look (e.g. fleabay, Amazon, MachineMart etc).
Any suggestions or recommendations anyone? Wink Cheers
Greg
Previous vehicles:-
Post #193839 13th Jun 2013 10:02am
dirtyharry
Well, solar charger arrived and is plugged in. Before connecting it, a reading with a voltmeter put the battery at only 12.1v, but after 30 minutes of "solar charging" it is already up to 12.35v! Smile
I ended up buying one of these, mainly as it is a well-known brand:-
http://www.amazon.co.uk/gp/product/B003M9F...&psc=1
It's about the size of a notebook and I've got it stuck to the windscreen on the passenger side and plugged into the cigarette lighter, which means I can disconnect it easily before starting the engine (recommended in the instructions!). It's not where I initially intended it to go, which was in the boot, but I think the tinted windows in the rear reduces the effect of solar panels, and it also makes it a pain in the butt to disconnect each time I start the engine.
Hopefully this means no more jump-starting!! Cheers
Greg
Previous vehicles:-
Post #195160 19th Jun 2013 2:45pm
If it were skinnier you could have put it on the sunroof blind between the sunroof and the blind and just left it there all the time and then tucked the cable into the headlining a bit like the solar sunroofs some cars now offer Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #195163 19th Jun 2013 2:58pm
dirtyharry
Just been out and tested your idea and it does fit. Thumbs Up
However, the sunroof is tinted (I think?) so I'll leave it for a few hours to see if it still charges as effectively as having on the windscreen. Wink Cheers
Greg
Previous vehicles:-
Post #195166 19th Jun 2013 3:06pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
So assuming it's up front as you suggested where did you plug it into. I thought the up front cig lighter sockets have no power when the ignition key is out? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #195167 19th Jun 2013 3:16pm
dirtyharry
It's plugged into the front lighter socket and the socket definitely works when the key isn't in the ignition. Wink Cheers
Greg
Previous vehicles:-
Post #195168 19th Jun 2013 3:23pm
Glad to have been a help to someone Smile
I reckon it will drop a bit but should be enough to keep a battery topped up! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #195176 19th Jun 2013 3:44pm
dirtyharry
Should have mentioned, I have put it back on the dash for the time being, until I have the confidence to pull apart the headlining and windscreen trim! Wink
I'm just hoping it will keep the battery topped up enough so that I don't need to use my Powerpack any more. Having to dig that out of the boot and connect it to the battery 4-5 times a week is getting tight on my t*ts! Banging Head Cheers
Greg
Previous vehicles:-
Post #195180 19th Jun 2013 3:50pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
^Bosch S5 110AH Thumbs Up
Still started my TDV8 after 15 days at the Airport, alarm armed and tracker system running too.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #195185 19th Jun 2013 4:35pm
dirtyharry
I wish I had invested in a Bosch S5 too (mines an Alphaline 100AH from Performance Batteries - it's complete Censored ).
I've had nothing but problems with it since I bought it last winter. I only need have the tailgate and passenger doors open for 5 minutes whilst cleaning the interior, and I end up with not enough juice to fire her up. Sad Cheers
Greg
Previous vehicles:-
Post #195189 19th Jun 2013 5:00pm
