![]() | Home > Technical (L322) > Tailgate lights switch |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
They do turn off after 15 or so mins, I think there is a few options in IIDTool regarding interior light control too |
MML Member Since: 01 Mar 2013 Location: Europe Posts: 47 ![]() |
Can anyone point me to the tailgate interior light switch? I've been looking but cant find it...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
The tailgate interior light swtch is an integral part of the tailgate lock motor.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
i believe you can switch all the interior lights off by double pressing the switch above the rear view mirror.. ... - .- -.
David: Well I just wanted to turn it off for those occasions when you have to give it a nice cleaning or just when you are deciding where all the cargo should go - like on vacations |
Why not just replace the tungsten bulbs in the fittings with leds, minimal current drain then.
That's what I did |
David, I thought about that, but what about the light color temperature? Dont they give the RR a "refrigerator" look? What do you use?
I used leds similar to these.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
<------- did the same - makes the car look more modern |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
If you push the lock on the upper tailgate to the locked position it should turn the tailgate lights off ( it works on mine ) then just press the boot release button to un lock before you close the boot.
