Home > In Car Electronics (L322) > 2005MY (MOST) reversing camera
Page 3 of 3 <123
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Thanks very much Stan for your continued advice.
The ebay picture seems to suggest you would be able to 'piggy back' onto an existing fuse.
But you've said use a unused/blank one - could you please clarify for me?
ive just put the car back tohether after running the Video cable through to the front, so Im really not keen on doing that again if I have to.
Any ideas if any of the fuses in the back will suffice? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #131716 18th Jul 2012 7:46am
you could piggy back onto an existing circuit or find one which is free due to maybe a item not being connected like rear heated seats for instance..
you have a choice with the rear fuses , again using a spare slot if there is one or piggy backing.
Post #131722 18th Jul 2012 8:51am
CBH25
In fear of you wanting to strangle me, where would I conect the ground wire in that piggy back set up? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #131749 18th Jul 2012 10:31am
ground it to any screw that goes into the body work, not 100% ideal but it works.. ... - .- -.
Post #131760 18th Jul 2012 11:27am
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
You could buy a gvif interface and connect the camera to it.
Its very easy to do and works when car is in reverse. Range rover td6 54 reg touch screen
Post #138523 30th Aug 2012 3:25pm
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I have the pre face lift touchscreen FFRR and would like the rear camera. Question
I have ordered a smb to rca lead from the link earlier in the thread, I should be ok with powering the cam via reverse light set up.
I wondered if anyone could send me a link for a camera they have used or the type I need please, there are hundreds on flebay??
Then activate on the CCF I assume my local indie dealer could do this??
Sorry guys I know this has been done to death but i spent a couple of hours looking through all the threads last night and am still a bit confused Confused
Cheers Thumbs Up
Post #194881 18th Jun 2013 12:42pm
where you want to fit it depends on which type you get ...as for activating it , the only diagnostics that i know will do that is autologic, faultmate and IIDtool...i personally think that the latter is the best value for money.. ... - .- -.
Post #194893 18th Jun 2013 1:25pm
zetjester
thx Stan
Very Happy
Post #194904 18th Jun 2013 1:37pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
You need the cam switched on in the CCF.
You will also need the front entertainment control module firmware updated.
Post #195019 18th Jun 2013 9:59pm
zetjester
Found a cam that will fit in place of the number plate light,
Which way did you route your camera wire to the head unit?
Post #195427 21st Jun 2013 12:35am
Tayas
Got a link? I've not seen one for the FFRR that goes there. I replaced my camera with an aftermarket one in the factory position. It works great but the actual positioning isn't ideal. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #195467 21st Jun 2013 11:14am
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
I finally connected up my reverse camera today (checked it was working first and no problems) and then installed. When I spliced into camera wires into the reversing lights, Brown (power) and Wht with yellow stripe (Earth?) coming out of the back of the reversing lap connector, i got a "Check Reversing Lights" error when tried the ignition (and no image).
Pulled it back out and the error went away. Plugged camera into the 12V jump started and it works well.
Any ideas why id get an error splicing into the Reverse lights?
More importantly what else could I use to get power from (preferably something in the tailgate that has power all the time)?
I thought all browns on cars are the earth.
It looks like you have crossed polarity when connecting into reverse light, this will probably cause the error light.
Post #195542 21st Jun 2013 7:51pm
Page 3 of 3 <123
