Home > In Car Electronics (L322) > Separate fuse for front lighter socket?
dirtyharry
I thought that all the cigarette lighter sockets ran off the same fuse in the cubby hole in the boot, however, I've checked fuse No.71 (20a) and it's fine and the middle and rear sockets both work but the front one doesn't. It was working ok on Friday but stopped yesterday after a few days of running my new solar trickle charger on it! Sad
So is there a separate fuse for the front socket, because I'm damned if I can find it? Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #195947 24th Jun 2013 4:03pm
You've got the correct fuse.
Probably a connection problem in the socket.
Have you tried a multi-meter to check for voltage and earth at the socket?
Post #195980 24th Jun 2013 5:36pm
try something else in the socket to make sure its that that has gone. ... - .- -.
Post #195987 24th Jun 2013 5:46pm
dirtyharry
OK - can someone explain this?
As suggested by Stan, I tried a 12v air compressor in the front socket and it works, without the ignition on. However, the cigarette lighter itself doesn't work in the socket whether the ignition is on or not, but it does work in the lighter socket in the rear of the vehicle!
Am I doing something really dumb here? How can it be that the compressor will work in the front but the lighter won't? Banging Head Cheers
Greg
Previous vehicles:-
Post #196091 25th Jun 2013 12:04pm
12volt sockets and ciggy lighter sockets are slightly different... ... - .- -.
Post #196100 25th Jun 2013 1:53pm
dirtyharry
Not sure I understand you Stan. In what way are they different? Just to clarify, I am putting the 12v air compressor in the front ciggy lighter socket and it works, but when I put the ciggy lighter itself (which belongs there!) in the same socket it doesn't. But the lighter works in the socket behind the driver's seat.
I'm confused! Cheers
Greg
Previous vehicles:-
Post #196103 25th Jun 2013 2:41pm
i think its to do with the depth of the socket which will [if shallow] activate the ciggy lighter but wont in a deeper socket...hope that makes sense... ... - .- -.
Post #196105 25th Jun 2013 2:48pm
dirtyharry
Ah, I see. That does seem to ring a bell from a problem I had a while back on an old Discovery.
However, that still doesn't explain why the ciggy lighter has stopped working in the front socket, but works ok in the rear one. Unless of course it never worked in the front one! I'm not a smoker so I have never tried using it Wink Cheers
Greg
Previous vehicles:-
Post #196106 25th Jun 2013 3:10pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I'm sure they are on different fuses anyway. I found out that just one of the four cabin sockets were working on mine (left rear). The rest were off. I fund a dud fuse in the boot box which will have hopefully fixed them all. (I forgot to check Shocked ) My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #196164 25th Jun 2013 8:08pm
dirtyharry
I wonder if it's different on later models, as the manual for the earlier L322 clearly states only 1 fuse in the boot cubby hole. Cheers
Greg
Previous vehicles:-
Post #196169 25th Jun 2013 8:23pm
