Home > Maintenance & Mods (L322) > just what is included in a dealer service? please.
johnboyairey
just what is included in a dealer service? i wonder as i am not going to a dealer as i have always serviced myself, and looked to indy's for stuff out of bounds etc. i know that an oil service is 'just the engine oil' (is it?) and we should also change the gearbox oil and draw off the brake fluid and push through some new, and coolant too. i have done some good work on mine, and only have the diffs to look at and some power steering fluid etc. and thats all fluids etc. --but do they do anything else? apart form reset the indicator? mine has (bought at)145k and all dealer history to 130k
secondly, is there a list of check items for the inspection 1 + 2 (mine is BMW engine VCool so apart from general mot items, like bushes, moving parts etc, corrosion, safety etc. is there a list that us commoners can peruse and check off ourselves. just so we can see the obvious, and get help if needed. and service ourselves! there's no way mine's going in for a £1000 after vat '1hr on the ramp' with a fag toking dealer mech. tapping a few bits, and ticking the box stamping it done! if anyone has a list or shedule, i think we would all read it! thanks.
Post #196052 24th Jun 2013 11:28pm
RR2008HSE
Here's a PDF showing exactly what needs to be done and when...
http://british4x4outfitters.com/Assets/PDF...verJAG.pdf
Post #196061 25th Jun 2013 4:33am
johnboyairey
that's great! -and it just shows you what you get for your money too! -(on an inspection) -i think our own yearly MOT is actually more thorogh than this, ie abs/headlamp aim/airbag system checked....(obviously apart from all fluids,) and this costs under £50. i always ask for any tips on what is likely to need attention straight after, as the guy i use is quite helpful. ie imminent problems, not YET causing issue, like rotten exhaust, underbody grazing, or even common range issues he sees. i have never been at the sharp end of range ownership, where the service record has to be in tip top condition, to keep so called car value at its peak. -whereas many of these owners cant even open the bonnet! -I can and will, do this work myself, and bask in the pile or £20 notes left over, to fettle my range, and buy some LPG to enjoy my pride and joy. thanks for posting this. i'm sure many will print it off!
Post #196074 25th Jun 2013 8:14am
RR2008HSE
Post #196085 25th Jun 2013 11:09am
Mustard
Is there anything like that for 2004 TD6's ?
Thanks in advance Very Happy
Post #197479 4th Jul 2013 12:52am
RR2008HSE
The 2006-2008 version I found says LRNA (Land Rover North America), so there wouldn't be a TD6 version. (JLR has never sold a diesel Land Rover/Range Rover over here.) How about taking a copy to a JLR dealer so they know what you're talking about and asking for the relevant version? They must have one somewhere.
Post #197483 4th Jul 2013 1:47am
Some nice short bread and a clean car ;-) 2008 MY Supercharged
Post #197491 4th Jul 2013 7:56am
in the wiki.. ... - .- -.
Post #197504 4th Jul 2013 9:14am
Mustard
Plenty in there to go on, thanks.
Im in the process of getting my local 4x4 specialist to do a gearbox oil change on my td6 as im presuming its never been done in its lifetime (93K on clock). Ive spent the past week reading on here all about the box and problems et al, mechanical sympathy and so on but Im still teetering on 'should I shouldnt I' as its not broken so should I fix it ?
First question the guy asked me is what box is on the motor, is it the ZF box and as I have been busy reading on ffrr I told him its the GM box so he gave me a price based on that but I was guessing LoL. Ive just saw this http://www.fullfatrr.com/forum/post105033.html#105033 in the wiki that I assume would inform me of exactly whats in the motor but unfortunately its not working for me Crying or Very sad
Post #197650 5th Jul 2013 1:03am
phil's helpful diagram has gone so i've emailed him to see if he can re-upload it. ... - .- -.
Post #197676 5th Jul 2013 9:15am
Phil has kindly sent me the transmission picture which i've entered into his post so its there to see... ... - .- -.
Post #197762 6th Jul 2013 8:32am
