![]() | Home > In Car Electronics (L322) > Harmon Kardon Logic 7 Audio Amplifier Failure |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
No Audio Sound at all but sound via RSE Headsets (Own AMP) so suspect AMPLIFIER Failure
I decided to try and fit a used Harmon Kardon Logic7 Amp picked up off eBay myself and just spent two hours stripping out the rear compartment of all the units and brackets in front of the Amplifier (Loads on a Vogue SE!).
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Now all you need to do is replace the Upper Tailgate doorseal. |
Is that the seal around the entire upper tailgate?
OK I will check the seal and reseat or replace. |
STAN you may want to put this in the WIKI as there is nothing for AUDI FAILURE - NO SOUND..... |
| barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213
As above it is a crap design.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
wiki'fied Gary.. |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737
Hi Gazellio
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
I got a load of large bags of silica gel off ebay for next to nothing and strategicall placed in the voids in that compartment, that way if I do get a leak it will be easy to see before the damage is done. |
| All times are GMT |
