![]() | Home > Technical (L322) > IID..which one? |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Yes they do display a list of faults codes and a brief 1 line describing what it is, there were originally 2 models for the L322, essentially the same but for different MY's
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
its worth reading these threads to get an idea of the usefulness of this diagnostic tool..
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
Where can I buy one, will they post to France do you think? |
I got mine from Britpart, they may be able to help you out. |
Just been on britpart site, they only seem to do lynx tool, and no price |
http://www.britpart.com/Accessory.aspx?AccessoryRef=4566
Thanks, inquiry sent |
in one of my links there is a 'best price' mentioned, cant offhand remember the dealer.. ... - .- -.
rjp996 Member Since: 28 Apr 2009 Location: East Sussex Posts: 22 ![]() ![]() ![]() |
I see on one of the links it talks about the aux heating. I've got a td6 without the aux heat option on my screen menu, can this tool actually put that option on, or just configure aux heat settings if already enabled. |
td6's normally have a fbh so can you set it from the menu? ... - .- -.
Yes I believe it will enable the button but you'll still be missing the telestart hardware so wont be able to start it remotely. |
No, but you will be able to start it with the timer in the menu on the nav. (Yes, the IIDTool can enable the Park Heat function on any diesel Range Rover (well, not the P38 or earlier...))
