![]() | Home > Technical (L322) > td6 turns over longer than it should before starting. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Had the same issue and it was an injector. Fortunately it was the first one and easy to change |
^ had the same issue, and the same resolution. The dodgy injector drains all the pressure off the fuel rail so it won't start. When it is running there's enough pressure for the other cylinders to run ok.
b20wht Member Since: 08 Apr 2013 Location: lincs Posts: 45 ![]() |
ooo great, how did you find out which injector it was? is there a test that can be done while they are still fitted? and dare I ask how much are they?
Leak off test. I didn't do it, it failed before I got round to it and then the garage fixed it. I hear it's quite easy to do. |
ok thanks. If it was an injector, would it turn over for longer the longer you leave it between starts? (ie more fuel leaked the longer its left) As mine seems to take 3-4 seconds every time no matter how long its left (other than the 2 times mentioned above) |
dunno. Mine was variable. |
It could also be the glowplugs if its taking longer to start the longer you are leaving it. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2712 ![]() ![]() ![]() |
Get it plugged in I had the same symptoms, injectors were the cause. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Could be the glow plugs, but im thinking injector like the others. I had exactly the same in my e39 530d (same engine) was one faulty injector. Just turned over for ages then fired. Is the glow plug light going out quickly? This will usually take longer to go out if the glow plugs are faulty.
Glow plug light only stays on for about a second or so. I don't think its glow plugs tbh, sounding more and more like an injector from all the comments. I will get it plugged in and hope it shows something. |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
leak off test is better for detecting overflowing injectors
