![]() | Home > Maintenance & Mods (L322) > Steering Wheel Tilt Motor replacement |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
This should help someone when dismantling the interior to get at the steering wheel tilt motor.
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
thanks RRUK |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2720 ![]() ![]() ![]() |
I need to replace the in/out screw as per meerbush, where is that on the photo? |
The in/out screw (reach motor) is not shown in my pictures but you can see if when all of the above is removed, however it is harder to get at. Discovery 4 HSE
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
There's no such size as a T24 [1] so assume it's a mistake. But if you have a set of Torx bits (always handy) then just find the size which fits |
Thanks Martin,have a set but they wont reach as the cowl gets in the way.Need to get some longer reach ones for the job,will report back later |
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 ![]() ![]() ![]() |
Coincidentally, I was puzzling over the T24 reference for the screw that holds the two parts of the cowl together, but I tried a T20 on a long 1/4" drive socket extension, and it was the correct size. I searched everywhere I could think of to buy a T20 screwdriver with about 6" of reach, before I gave up, and then I found all the components I needed in my Halfords Socket set |
Got the shroud off.Used 2 Teng torx screwdrivers and the sizes are T20 x 1 and T25 x 2.
