![]() | Home > Technical (L322) > Uprating the MGW of the car? |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I read somewhere the FFRR is rated to tow up to 4 tonnes with coupled brakes.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
mmmm . . . . interesting
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8769 ![]() ![]() ![]() |
Its less about the weight and more about the length. In the uk the max allowable length is 7m excl drawbar, unless the towing vehicle has a mgw of 3500kg or more. Over 3500kg the max length is not applicable so long trailers and caravans over 7m can be towed..... There is nothing that can't be fixed with a hammer😜😜
Might just do that TugRR. There is nothing that can't be fixed with a hammer😜😜
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi, my dads a VOSA vehicle inspector i will ask him for you if you want?
i have asked my dad and he said that you need to get in touch with the manufacture and ask if there is anything can be done to up rate the vehicle to tow greater than 3500kg he said VOSA would only look at documentation from the manufacture before they will go any further with approving it. He will double check this tomorrow at the testing station when he goes to work.
