![]() | Home > Technical (L322) > Headlight washers |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
Did the 2006 facelift but never connected the headlamp washers, car failed mot today for this, does anyone know what diameter hose i need to fit the washers ? otherwise i have to take the bumper off to see,
took the bumper off, only took 15minutes, i used a 10mm hose with a plastic reduction to fit the old hose, the right one worked fine but the left was kind of weak so i lengthened the right hand hose to the same length as the left one to even things out, now it works fine, i didnt want to remove the headlights cos they check the alignment when she goes back to the testing station tomorrow, and here in belgium theyre a bit fussy, as for the pump and bottle i cant see why you would need to change it 2002 td6 vogue, 06 supercharged facelift
hi, when i had my conversion they said it would be extra to have these working,around £260 as i would have to have a new bottle and hi-pressure pump. it was on my to do list just more at the bottom then the top...
yep 3 pumps, the headlights and rear wash er go around the front bumper carrier and the windscreen washers go through the engine bay , kinda weird that the rear goes so far instead of going through the engine bay, maybe its been changed for left hand drive ? 2002 td6 vogue, 06 supercharged facelift
thanks darren, i did have a quick look when i was changing my side lights for led's, you have to take the lights out to get to them due to the conversion, buy the way..3 screews for the grill and 3 for the head light, the adjuster is not removed so allingment remains ok as when you replace the light it clips back in to the adjuster..
