![]() | Home > Duckworth Parts > Spare wheel lifting strap / Pollen filter |
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217
Hi Paul
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
Dan - PM sent
| Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305
What's a spare wheel lift strap/cradle? Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
its a couple of straps with a rubber type handle ...the straps go underneath the wheel/tyre and you use the handle to pull up and out the wheel/tyre.. ... - .- -.
. . . . clever bit of kit, but for some reason not fitted to all cars |
| Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267
If you use it correctly, the handle slots into the lock in the centre of the lower tailgate (when it's in the up positions) and then you just open the lower tailgate and the spare wheel is pulled into a position where you can slide it onto the lower tailgate.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Factory fitted till 2005 facelift... Then Ford junked it... One of the best bits of the early cars when you have a back like mine! |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
I had it in my last one which was an A6 chassis number . Took it out and fitted it to my new one, just make sure you get the plastic strut to pop in the locks and hold the lower tail gate open . 2008 MY Supercharged
| Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261
Out of idle curiosity, is this something that can be retrofitted to later models?
I had it in my last one which was an A6****** chassis number . Kept it for my next one , make sure you get the plastic strut to hold the tail gate open . 2008 MY Supercharged
| Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267
Just checked... Got the strapping in my FF, but no plastic strut to hold the tailgate down
EPX000030 £3+VAT You can paypal direct using - www.paypal.me/duckworthparts
Thanks again Dan..
all received Trev |
