![]() | Home > In Car Electronics (L322) > I phone 5 bluetooth pairing |
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 ![]() ![]() ![]() |
I use an IPhone 5 with no problem. The software was updated before I took delivery as it wasn't working at test drive. Turned out to be a blown fuse but software done anyway. I had lots of problems with Sport , mainly the phone would pair then randomly disconnect, usually during a call and this was diagnosed and needing new software. TDV8 Vogue SE 2009.
filthyliam Member Since: 01 Aug 2011 Location: Lincolnshire Posts: 81 ![]() ![]() |
thanks gonna try to pair i phone to I phone first as i have been told you can do this just to confirm that there are no bluetooth issues from the phones then speak to dealers and see if they can help will also look at the installation manual and user guide on Bimmernav to see if I can find anything |
tried to pair i phone 4 with my 5 and they wont connect just watched a vid on youtube pairing a 5 to a car he goes into settings bluetooth on which starts to search and puts the bluetooth symbol in the top right hand corner to the left of the battery symbol. Now just a small point but when he then presses the home key on the I phone it stays on, mine doesn't it goes off but is that because it cant find anything to connect to or a fault with the phone? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Your iphone 5 will never pair with your car until you get the ulf in to pairing mode.
right a development!
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
Wrong thread sorry |
I have also now had a reply from Bimmernav who have suggested turn off the wi fi on the phone backup the phone book on my computer and delete it from the phone then try to connect as sometimes the phonebook causes problems ???? Also check the phonebook to ensure all entries are A-Z characters and numbers are all 0-9 which they are. And check that settings are configured to allow other bluetooth devices to control ( dont think you can do this on an I phone if you can I havent found it)
