![]() | Home > In Car Electronics (L322) > Nav Head unit rebooting |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Got stuck on the motorways on the way home from the office yesterday and the car started to play up (I need a new rad and the gearbox needs its cooling sorted) gears would stay in higher range for longer etc. Then my old problem resurfaced - the head unit (for nav radio etc) started to reboot. The longer I stayed in the slow moving traffic the more times it rebooted. As soon as i was off and moving again it settled down and didn't do it again all the way home.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Mine does reboot from time to time of its own accord, no specific symptoms, although it often happens on the way home from work, about five miles from home, after climbing a a short hill |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Logically speaking when you are in slow moving traffic your engine is not revving very high, so the alternator is maybe not outputting enough voltage to charge the battery
That's an interesting point - I hadn't considered that, better give the battery a check. "On first name terms with my local Dealer......now."
Mine rebooted on startup during the winter when the battery was a bit low, usually at the same time as slow lock operation (including steering lock) tired cranking and "Special Programs Off" message from TR (presumably this was rebooting too)
stop car
Gary - what does that sort then? "On first name terms with my local Dealer......now."
It sorts the constant reboot issue and appears to be a permanent fix |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
I had something like this happen on my old BMW with a Mk 3 sat nav. It was a faulty (cheap) disc that the computer could not read easily that caused it to reboot. Changing to a new disc solved it. Tom
Ok fuse 49 trick done - will see how that goes "On first name terms with my local Dealer......now."
Remedy should be immediate ? |
Right finally spent some time diagnosing this - it turns out it is the nav computer that is causing the problems with reboots. Taken it out of the car and the radio etc all work fine with no rebooting - but I am back to the horrible screen display that feels circa 1970
Probs with a weak laser mis-reading the nav disc can also cause reboots.
Ordered one and will see if that sorts it - thanks for the advice. "On first name terms with my local Dealer......now."
