![]() | Home > Technical (L322) > Tdv8 (07) vibration at low rpm(D engaged) and ca 2200 rpm |
andrzjb Member Since: 01 Jun 2013 Location: Poland Posts: 19 ![]() ![]() |
what size wheels do have fitted?
19 oem with new Vredestein Ultrac Sessanta balanced with stadard(no extraordinary LR) procedure?
Can you reset the gearbox to the original software setting? |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Is there any noise or just vibration? Could it be something loose? Mount, exhaust, etc.
probably ... I asked guys from another LR service they informed me that back to manufacturing soft is possible (of course with some extra charges ![]() but vibration at 2200 rpm "was& is" no matter new or old gearbox soft.... answering another question... at low rpm no additional sound or noises .. in 2200 rpm engine is louder however no noises like some parts touching another only engine..... |
In stationary all is perfect no noises no vibration no matter how rpm is Enigne mountings had been checked by LR ... but if you have some special "in house" method to check it i will do it for sure (I dont trust LR official service guys in Poland too much) |
OK we can thankfully rule out any Engine problem then |
Wheel Bearings ? |
I'm starting to lean towards injectors/fuel related issues. Even though no faults are logged related to the injectors, maybe one or two are not doing exactly what they need to.
![]() one question , how to check injectors .? out of the car on speclist table or via diagnositc soft? if soft how to do it to be sure ? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Sounds like an injector fault to me, normally will show up on diagnostic tool, however you can get a garage to do a leak off test to confirm.
Hmm hopefully u r right.....however i dont See any smoke from exhaust and error codes on engine ecu |
