![]() | Home > Technical (L322) > Misfire help. |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Sounds to me rather than a coil pack jiggered it's more likely to be a lamda sensor as a misfire would cause more unburnt fuel and therefore "system too rich".........anyways lambda are cheaper than coil packs.
Simusmaximus Member Since: 06 Mar 2013 Location: South Wales Posts: 60 ![]() ![]() ![]() |
How much fuel was in it?
I asked to see if the fuel level was quarter tank!
Cheers Gazellio. When I bought the car, the chap mentioned about that issue with L322's but I have tried to keep it above that quarter tank mark at all times. As it hadn't even got to the quarter mark I didn't think about that. It was bloody hot weather yesterday, so the gauge may have been a bit higher than actual tank level, so possibly was below quarter?. ![]() ![]() |
Last time it happened to me at the very top of the Woodhead pass I ground to a halt and the engine would not run for more than a few seconds. However half an hour later I was able to start it and drive nearly two miles to the shell garage near the M1. THe Jet pump may overheat and stop working then cool down and work again (for a while) This may explain you starting the car OK after it has been recovered.
Sounds indeed like the balance pump issue, very common on FFRRs. At least it is the first thing I'd suggest to address. Running fuel injector cleaner, using "clean fuel" and changing filters is a good way to go anyway but you are likely looking at the fuel pump unit here.
Thanks for the help guys, sounds like I need to look at the pump and fuel filter then. "I got him boxed in like a turtle's pecker!". |
The "cheapest" temporary solution is keeping the tank above 1/3 full for a while and see if you have any issues. MY 2010 5.0 SC Galway green and sand interior!!
[ mod edit, there is no need to quote when replying to the above post ]
Thanks mod, will bear in mind next time.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
@simusmaximus: was your problem solved? if yes what was done to solve it - seems like i have a similar problem with my 2004 v8.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
In my experience, if it's not the JET pump issue, it's often the Mass Air Flow sensor. They seem to pack up at high milage just for fun.
