![]() | Home > Technical (L322) > Td6 Rear driveshaft problem |
You need to remove the wheel, caliper, disc top & bottom rose joint bolts, toe control arm, hub nut. The top rose bush bolt needs to be marked and go in exactly as it came out as it is eccentric and adjusts the toe in of the wheels |
Correction, the toe control arm eccentric bolt adjusts the toe in/out, the rose bush eccentric bolt adjusts the camber |
