![]() | Home > My Range Rover > Tell me what you'll think 2003 conversion 2012 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35661 ![]() ![]() |
never seen RRS headlights on a fullfat before, interesting.. ... - .- -.
You not going to get a grille to fit IMHO.... |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Looks odd.
if he's clever enough to fit RRS headlights to a fullfat then i should imagine that manufacturing or adapting a grill would be eazy peazy.. ... - .- -.
Actually the outer profile is quite similar:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Looks very close to a 2010> grille?
My problem is why spend the money on a 2012 conversion if the end product does not look like the car you are trying to copy? A Mish Mosh is not to be desired. Hopefully te 2010+ grille will fit and t may look like a L3222 2010+ |
Have you never watched, ride my pimp or wet coat customs Gaz?
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
How are you planning on rejoining the grill back together in the mesh ?
Wonder will Evoque lights and grille fit |
Errgh YES all of them.... ![]() PS: WET COAT CUSTOMS PIMPS is my fave ![]() |
flow11234 Member Since: 08 May 2013 Location: pa Posts: 36 ![]() ![]() ![]() |
To answer everyones question I was rushing teying to get my project done with very little money didnt know the conversion was so costly.
[/img
Sometime you have to show ppl beter then you could tell them Sport headlights on the fullfat RR probably the only one out there Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Did you need to adjust/shave the L322 grill or did it fit exactly?
