Home > Technical (L322) > Condensor Electrical Fan not working
andyos
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi guys, I've just had my air con refrigerant regassed on my 2006 RR Vogue 3.0 TDI and the guy who did it tells me that the electrical fan is not kicking in when the air con is switched on. He showed me the pressure rising and tested that the is power to the fan (~14V?) and from the other side of the fan's connection block there's the same voltage too. He said that the viscous fan would cool the compressor ok whilst the car is moving but in traffic or standstill it would overheat....his suggestion is that the fan needs replacing but is there anything else that could have failed and is this diagnosis correct? Thanks, Andy
Post #199093 16th Jul 2013 7:22pm
...funny, mine has the same problem....
Post #199118 16th Jul 2013 9:28pm
andyos
Lol, the thing is, I don't know if it's ever worked! All I know is that the air con has worked for the last 3 1/2 years that I have had the car then stopped....on reassign it now works but apparently the fan doesn't. I'm going to ring my local independent garage in Leeds tomorrow but I'm guessing they will say it needs replacing....
Post #199119 16th Jul 2013 9:31pm
Brace yourself for the cost of the fan...
Post #199124 16th Jul 2013 9:39pm
andyos
Oh dear, I don't like the sound of that.....are you using your air con without the electric fan working? Could it be anything other than the fan if power is being sent to it?
Post #199138 16th Jul 2013 11:16pm
I don't know much about it. Found out mine is bust today, hence the spookey coincidence.
Post #199142 17th Jul 2013 12:00am
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Had my air con re gassed yesterday all seemed ok, smelt burning, realised the belt was slipping on the pump because the pump is Censored !! Gotta get a new pump now!! Damn it!!
Post #199151 17th Jul 2013 7:41am
