Home > Maintenance & Mods (L322) > TPMS Woes
RR2008HSE
TPMS Woes
Keep getting a ransom but very frequent 'Check All tyre pressures' warning in both the message centre and the amber warning light. Mechanic said there are no fault codes and all sensors are reporting in OK. Longer motorway drives sometimes temporarily fix the problem but it soon returns.
(Yes, tyres do have the correct air pressure in them.). One tyre has a slow leak, so it does require topping up.
Battery and alternator just checked and are good.
It's annoying! Big Cry Any ideas/helpful suggestions? Bow down thx
2008 FFRR HSE LUX (US spec), 4.4 Jag V8
Post #199134 16th Jul 2013 10:27pm
Googsy
From what I hear they frequently cause issues a lot on here simply removed the tpms valves and replaced with std. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #199136 16th Jul 2013 10:33pm
RR2008HSE
Yes, you're right. I just checked and they aren't required by law in Canada. However, I was wanting to get a fix instead of just binning them. Very Happy
Post #199144 17th Jul 2013 12:03am
ebajema
Although your car is quite new the batteries may be running low. They normally last for around 7 years. On Ebay you can find sets that are quite reasonably priced but make sure you have to correct frequency, you need the North American frequency (same band as the keys), 315 MHz if I remember correctly (but please check).
On mine the TMPS is working perfectly and has been since I have it although the batteries should be empty by now , maybe the heat here allows them to last longer. MY 2010 5.0 SC Galway green and sand interior!!
Post #199175 17th Jul 2013 10:03am
They do appear to be more bother than they are worth for some people. Personally, at the first sign of ongoing problems I would bin them rather than spend money repairing/replacing. Previously..
Post #199180 17th Jul 2013 10:15am
As above! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #199181 17th Jul 2013 10:21am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
As above Thumbs Up
I would also bin them due to the corosion problems you get on the valve stems.
In answer to your issue, it is probably the batteries on their way out as has already been suggested. Temperature and the amount of miles you RR does will affect the battery life 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #199202 17th Jul 2013 12:25pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
If you are getting 'check all tyres' message I'd suggest that points more towards the RF reciever module or possibly TPMS ECU.
Post #199209 17th Jul 2013 12:50pm
SteveMFr
Site Sponsor
People are turning the TPMS off too. Cool
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #199289 17th Jul 2013 8:24pm
Andy_J
@ Katash - the check all tyres message indicates one of the road wheels is either low on pressure or not returning a signal.
I took SteveMFr advice and turned my TPMS last year after investigating the system.
The TMPMS system is good and effective when the batteries in the sensors are in good condition, its only problem is corrosion of the valve stems which is just dangerous. 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #199325 17th Jul 2013 10:32pm
Katash
Ah I thought it would return individual sensor status, mine warns when the spare in the boot is low and states 'Check spare tyre pressure' or something similar.
My valves are corroded (but not too bad) - changing the rear tyres tomorrow so decided to do the sensors while I am at it.
Post #199333 17th Jul 2013 11:01pm
alx
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Nara Bronze
I've recently replaced all 4 TPMS sensors but still get an intermittent message light on the dash. Very annoying given the outlay on 4 new sensors. Now I have 6 months warranty from Stratstone and would like them to look into it, does anyone know if this is covered?
Thanks.
Post #292232 11th Nov 2014 4:46pm
RR2008HSE
Remember, you have FIVE. It could be the one on the spare causing the problem if everything else is good. The spare tyre TPMS won't automatically synch with the car like the other four.
Post #292278 11th Nov 2014 8:38pm
Vorbis
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
I've replaced all the tyre pressure sensors and still have the warnings. Front nearside is registering 0 volts apparently, next step is a new ecu
Post #292289 11th Nov 2014 9:09pm
alx
Ah, yes of course! Will check pressure in the spare wheel tonight. Very Happy
Post #292445 12th Nov 2014 12:03pm
