Home > Maintenance & Mods (L322) > Help on how to check if radiator leaking
vogue12345
Hi guys
This is related to my other thread of losing coolant.
The warranty company need a garage to diagnose the problem (the loss of coolant) for which my local garages want silly money for - and no surprise my policy covers everything in the cooling system but a radiator! So hoping it's something else.
Is there a way I can check whether it is indeed the rad or if it's a pipe etc or is a garage the only way?
Any advice on how to go about checking this would be much appreciated
Thanks!
Post #199232 17th Jul 2013 4:16pm
i would have thought the simplest way would be to get it up to temperature and maybe do a visual inspection and then maybe a piece of tissue paper to see if there are any fine sprays and obviously taking care not to touch any moving parts. ... - .- -.
Post #199237 17th Jul 2013 5:08pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Think you can get leak detector kits, a fluorescent dye you can add to the coolant then run the system and shine a special torch to see where the leak it
Post #199239 17th Jul 2013 5:14pm
take the fan off (left handed thread) undo the 4 little rivit things and remove the undertray 12? 10mm bolts then remove the fan cowel. use a torch and mirror to look for staining. should be red/orange or green/blue colour. you could try a pressure test but woukd req plugging the holes in the rad and a way of pressuring the system. or start the car without the above buts and look for a leak when warm. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #199279 17th Jul 2013 8:09pm
vogue12345
Appreciate the advice guys - will try and look at it!
If it helps I was looking back at previous jobs and not sure if the rad was changed - for an entry on service by Town & County Aberdeen dated 2009 and says Cost £876.62 - "s/f front to rear brake pipes.renewed radiator.pipe and transmission thermostat.
So not sure if that's a new radiator or radiator pipe!
Water pump and coolant was last done in 2008 so maybe it could be the water pump.
As a general rule how often should the coolant system be flushed?
Thanks!
Post #199329 17th Jul 2013 10:47pm
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
vogue12345 wrote:
I was looking back at previous jobs and not sure if the rad was changed - for an entry on service by Town & County Aberdeen dated 2009 and says Cost £876.62 - "s/f front to rear brake pipes.renewed radiator.pipe and transmission thermostat. So not sure if that's a new radiator or radiator pipe!
I would suspect that includes a new rad - or it should, since when mine was done (about the same time) the job was £580, of which the new rad was £290. Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #199344 18th Jul 2013 6:21am
You can get a pressure kit that you fit to the expansion bottle which you can then use a footpump or car pump on and get a little pressure in the system and listen for leaks with the engine off but nice and hot to make the thermostat stay open Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #199357 18th Jul 2013 9:17am
Post #199360 18th Jul 2013 9:32am
