Home > Technical (L322) > Battery drain Electric Seats, Windows, Cabin lights etc
jumbocar
2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi
About a L322 2004 4.4
How much playing around with the Electric seats, Windows, Cabin lights, Folding mirrors, Radio etc while not running would drain the battery so much that the car can't start ? - 10, 20, 30 min or more?
Input appreciated
Post #199365 18th Jul 2013 9:50am
depends how good/new your battery is... ... - .- -.
Post #199368 18th Jul 2013 10:05am
jumbocar
I see
After a week of sitting in the garage, I'm able to start the car but only if I don't have an extended play with the electrics.. Otherwise car won't start without a jump
Also, I'm able to start once fine, but if its just left to idle and turned off, I won't be able to start again without a jump start
Wondering if its just in need of a new battery or if there is a drain somewhere
No idea how old the battery is. Do they have manufacture dates stamped?
Post #199372 18th Jul 2013 10:19am
FF's are very electricity-intensive, so you're better off switching the engine on if you're planning on using the electrics for those periods of time.
It never hurts to change the battery if you're unsure. They don't normally like being flattened on deep-cycle routines like that and will tend to hold a full charge for less time afterwards. Si. <This is my name.
Post #199377 18th Jul 2013 10:34am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Multimeters are pretty cheap and easy to use, get yourself one and measure the battery voltage.
Post #199402 18th Jul 2013 1:56pm
dirtyharry
Multimeter is deffo the way! Without one I would never have found the root cause of my battery drain problem.
I left my drivers door open for 1 minute and that took enough juice out of the already poorly charged battery to prevent it starting.
Before splashing out on a new one, you could always get the battery checked out at an auto-electrician. They usually charge less than a tenner. And you'll need a really good quality battery on an FFRR to cope with all the electrics! Thumbs Up Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #199422 18th Jul 2013 4:18pm
